majki7 začátečník
Založen: 04. 05. 2005 Příspěvky: 31
Zaslal: st květen 18, 2005 11:16 pm Předmět: Ktery si myslite, ze je lepsi, jaky je mezi nimi rozdil? |
S55 Blacklist patch adapted by Mich3L for V91 (version 2)
; S55 BlackList original by SiNgle (M55)
; S55 v20
; don't play any sound / vibra when caller is in black list or reject them
; 2004 by ACiD [mrp]
; GSM Development Crew www.gsm-dev.com
; join us at http://www.handyhacking.com/
; improved by amsik (reject caller from blacklist)
; default Black List is the 5th from the top
; change this here: (03 = 1st, 04 = 2nd, 05 = 3rd, ... , 07 = 5th)
003B9A06: FF 07
64B21A: 8880F08C FA7B009A
003B9A00: FFFFFFFFFFFF 8880F08C46F8
003B9A07: FFFFFFFFFFFFFF 002D02FAA41EB2
; reject caller:
003B9A0E: FFFFFFFF DA630E9E
003B9A12: FFFFFFFF 9880DB00
; or don't play any sound/vibra
;003B9A0E: FFFFFFFF 9880DB00
---------------------------NEBO-----------------------------------------------
; +BlackList original by SiNgle (M55)
; S55 v20 by by ACiD [mrp]
; adapted for S55 v91 by Mich3L
; this patch conflicts with older blacklist versions!
3B9A00: FFFFFFFF 8880F08C
3B9A04: FFFF 46F8
3B9A06: FF 07 ;blacklist group number+2 (5group+2=07)
3B9A07: FFFFFF 002D05
3B9A0A: FFFFFFFFFFFFFFFFFFFF 46F80C002D09FAA41EB2
;reject with 'busy':
3B9A14: FFFFFFFF DA63C69D
3B9A18: FFFFFFFF 9880DB00
;or reject with message 'call ended'
;3B9A14: FFFFFFFF DA63C69D
;3B9A18: FFFFFFFF 9880DB00
;or don't play any sound/vibra
;3B9A14: FFFFFFFF 9880DB00
3B9A1C: FFFFFFFFFFFFFFFF 9810FAA4A6B18810
3B9A24: FFFFFFFFFFFFFFFF D7400B00F3F2A82A
3B9A2C: FFFFFFFFFFFFFFFF 47F22E003DF5D740
3B9A34: FFFFFFFFFFFFFFFF 0B00F3F2AA2A47F2
3B9A3C: FFFFFFFFFFFFFFFF 70002D1C98109880
3B9A44: FFFF DB00
3B9A78: FFFFFFFFFFFFFFFF D7400B00F2FCAC2A
3B9A80: FFFFFFFFFFFFFFFF 28C166FC0700DA92
3B9A88: FFFFFFFFFFFFFFFF 40A598109880DB00
;locale=Czech_Czech Republic.1250 |
Zaslal: st květen 18, 2005 11:27 pm Předmět: |
Ta 2 verzia je novsia. _________________ Kdo umí, ten umí. Kdo neumí, ten čumí. |
Anonymní
Zaslal: st květen 18, 2005 11:34 pm Předmět: |
Nu to jsem take pochopil, ale ja spis myslel rozdil ve funkcich, v te starsi jsou tri moznosti, v te nove jen dve.
V te stare si slo vybrat, zda zahlasit obsazeno ci ukonceny hovor, v te nove je pouze odmitnuty hovor. Netusite, co si pod tim predstavit, co se objevi na druhe strane, kdyz bude v blacklistu? |
majki7 začátečník
Zaslal: st květen 18, 2005 11:35 pm Předmět: |
Jsem byl odhlaseny, psal jsem ja.  |
majki7 začátečník
Zaslal: pá květen 20, 2005 9:13 pm Předmět: |
Mimochodem, ta varianta, kdy je vypnute zvoneni i vibrace, na to preci neni potreba zadny patch. Skupinu si pojmenuji Otravove, a zadam zadny zvuk a vypnu vibrace....nu a mam to same, co nastavuje patch..... |
