sassaki kolemjdoucí
 Založen: 21. 12. 2005 Příspěvky: 8 Bydliště: Brasil
Zaslal: út únor 07, 2006 7:14 pm Předmět: dissable OTP |
I obtained to change the IMEI, but of the OTP not.
How I can I disactivate the OTP, of siemens?
lacibogi čestný člen
Zaslal: pá únor 10, 2006 11:08 am Předmět: |
What´s your problem? Why do you need to do it? _________________ C(ME)75
Lasky |
sassaki kolemjdoucí
Zaslal: pá únor 10, 2006 3:01 pm Předmět: |
Lasky napsal: | What´s your problem? Why do you need to do it? |
my phone is blocked by the operator, would like to modify the IMEI, to make called in the operator. I changed the IMEI of phone, but the OTP I do not obtain to change.
Zaslal: pá únor 10, 2006 4:11 pm Předmět: |
Hmmm, OTP is an one-writable memory, you know. Theoretically after flashing new bcore OTP would be unlocked but practically it´s not so.  _________________ C(ME)75
Lasky |
sassaki kolemjdoucí
Zaslal: pá únor 10, 2006 4:22 pm Předmět: H W Y |
Lasky napsal: | Hmmm, OTP is an one-writable memory, you know. Theoretically after flashing new bcore OTP would be unlocked but practically it´s not so.  |
Humm, does not have as to make. the friend szoza2 postou this tutorial one, coce can speak to me if it functions? I do not know to read Russian, I am difficult to understand what it spoke.
http://www.mobile-files.ru/forum/showthread.php?t=45258&page=15&highlight=dissable+otp
thank you |
