omer67 kolemjdoucí
Založen: 09. 03. 2006 Příspěvky: 11
Zaslal: čt duben 06, 2006 3:29 pm Předmět: Need help with V-Klay |
I am a new user and I can not understand manual for patching my m75.When I turn it on it apears"Card defect or not formatted'. I have found patch for that but I can not do it because I dont anderstand chech lenguage.If anuone can send me how to do in english or serbo-croat I will be greattful to him or her. |
lacibogi čestný člen
whitewash táta fóra
0.00 SMM
Zaslal: čt duben 06, 2006 4:11 pm Předmět: |
There should be somewhere here also English version of basic HOW-TOs to patch etc, but I can't find them... so i'll try to write a little 'manual' myself:
1.) You need to have DCA-510 cable to perform service operations. Press *#06#, More and look for the Acc: directive.
2.) Load the http://www.siemensmania.cz/download.php?file=/software/px75v1.rar px75v1 application into your mobile and run it. It will take approximately 5 minutes for the app to calculate your HASH and ESN values. Leave the application started.
3.) Start the http://www.siemensmania.cz/download.php?file=/software/x65PapuaUtilsV077.rar Papua utils. It's in Russian, so you might understand it. I will describe all functions in English, as I have the czech version and I don't know how are those functions called in Russian.
Connect your phone with the cable to the PC and look for the number of COM port where the cable is connected (you will need it)
4.) In the first tab in PU, select your COM port, where the phone is connected. Then, In the Codes tab (the second one) write down HASH(without hyphens) and ESN (the one for PU, NOT for x65flasher). When done, close the px75v1 application in your phone. Now press 'Get IMEI' button in PU. Your IMEI should appear in the appropriate field.
5.) Now press Calculate SKEY+BKEY button. Wait a while, PU is calculating...
6.) When your SKEY and BKEY appears in appropriate fields, press the PV VKD button. A dialog appears, browse the path to V-Klay\Data\Loaders directory. Then click Save in the dialog. PU saves the 'loader' in that folder.
Now turn off your phone.
7.) Now start the V_Klay. You can select the English interface there. In the 'Phone type' listbox, select x65 Bootkey & New flash option. Now select correct COM port, press REFRESH and then SHORTLY press red button on the phone (if you hold it, phone will turn back on - you DON'T want that). The green square will become red.
8.) Make FF backup (not complimentary, but STRONGLY RECOMMENDED!!)
After FF bckup is complete, you can load patch, then click Apply patch and it will be recorded in your phone in short while. After applying all patches you want, click the button with red circles near the red square. You can disconnect phone from cable now and turn it on.
I hope I haven't forgot anything... If this won't work, just write here... _________________ Siemens CX75 -> QTek 9100 (T-Mobile MDA Vario) |
whitewash táta fóra
0.00 SMM
Zaslal: čt duben 06, 2006 4:12 pm Předmět: |
Great.. Lasky has found it... I was looking in the main section of this site, thought it was there as an article _________________ Siemens CX75 -> QTek 9100 (T-Mobile MDA Vario) |
omer67 kolemjdoucí
Zaslal: čt duben 06, 2006 6:04 pm Předmět: |
Every thing is great to steo number 5.) Now press Calculate SKEY+BKEY button I cant find it.Witch buton I have to push? |
Zaslal: čt duben 06, 2006 6:14 pm Předmět: |
Number 2. _________________ C(ME)75
Lasky |
omer67 kolemjdoucí
Zaslal: čt duben 06, 2006 6:42 pm Předmět: |
I got it.When I push it first comes "Ðàñ÷åò êëþ÷åé... "and on the end of window blue line grovs,bat olmost at the end stops and nothing happens SKEY and BKEY doesnt appears just "Êëþ÷ íå íàéäåí!"Where I have make a mistake? |
omer67 kolemjdoucí
Zaslal: pá duben 07, 2006 9:18 am Předmět: |
Still have the problem.I cant calculate SKEY and BKEY do You know why?I have tried to calculate even in service mode,with open and close px75v1 aplication every time the same messages apears.(I have wrote it in prevous post).I dont understand enithing. |
whitewash táta fóra
0.00 SMM
Zaslal: pá duben 07, 2006 12:49 pm Předmět: |
Try the english version of PU and write that error message in English. _________________ Siemens CX75 -> QTek 9100 (T-Mobile MDA Vario) |
omer67 kolemjdoucí
Zaslal: pá duben 07, 2006 1:33 pm Předmět: |
I tried,Lasky put a link to english version and I have download it but it is the same as I wrote,no mater english or russian version. |
Zaslal: pá duben 07, 2006 1:51 pm Předmět: |
I know that you still have problems. But now PU writes you the error in enlgish and we can better understand it. _________________ C(ME)75
Lasky |
omer67 kolemjdoucí
Zaslal: pá duben 07, 2006 2:00 pm Předmět: |
That is the problem.PU english version doesnt wrote message in english still in marks as I wrote before and I cant understend. |
whitewash táta fóra
0.00 SMM
Zaslal: pá duben 07, 2006 2:16 pm Předmět: |
1.) Make sure you wrote 0's, not O's in the HASH. The same for ESN.
2.) Try to re-write ESN this way: 12345678 -> 78563412 _________________ Siemens CX75 -> QTek 9100 (T-Mobile MDA Vario) |
omer67 kolemjdoucí
Zaslal: pá duben 07, 2006 2:36 pm Předmět: |
I have make a mistake!I have wrote O instead 0( it is very similar on the phone)now it works!Than You all for your help and understanding. |
