:: Zobrazit téma - How to pach my sx1
How to pach my sx1
Sameco
Založen: 02. 10. 2005
PříspěvekZaslal: pá květen 19, 2006 10:27 pm    Předmět: How to pach my sx1 Odpovědět s citátem
How I can pach my sx1 that i could have themes for him ? please help me I want to have themes on my phone Shocked Brick wall
Gwin
Založen: 27. 09. 2004
0.84 SMM
PříspěvekZaslal: so květen 20, 2006 10:04 am    Předmět: Odpovědět s citátem
http://www.siemensmania.cz/content.php?id=405
http://www.siemensmania.cz/content.php?id=263
Sorry, I haven't got time to translate it.
diablo
Založen: 29. 11. 2004
PříspěvekZaslal: st květen 24, 2006 12:50 pm    Předmět: Odpovědět s citátem
The first thing you need is usbdriver and, of course firmware 15.
All patches can be found here and here.
Exclamation Make sure you carefully read all the patches before you apply them Exclamation
Some of the patches require certain files to be put on Memory Card BEFORE you apply them. See the content of each patch to know what files should be put on disk C(phone memory) or E (MMC)
Exclamation Fully load your battery to prevent any damage!!! Also, take out your Memory Card (MMC) and SIM card Exclamation
Patches are applied via WinSwup Memory patcher
After you downloaded all these programs and all patches you want, switch off your fully loaded SX1 and attach it to DCA-540 cable (supplied with phone). While holding the joystick pressed switch the phone on. It should say 'Connect SX1 to PC and start update software' (or something similar).
Run firmware 15 on your computer. Do NOT press 'Start' yet. Click 'Serial config' and set 'USB 0' as shown on the picture.
Majority of the patches are applied to 'Core-Img (Z1)' but there are a few patches that need Z2 or ROLF, so read the patch carefully before applying.
The next step consist of launching WinSwup Memory Patcher. This application applies all the patches to the firmware in RAM of your computer before the actual upgrade takes place. That is why you need to run (not start) the software upade firmware 15.
Now, open your patche and click 'Apply' Wait, cause it may take up to 5 minutes to apply a patch. A message will appear to confirm that the patch has been applied. Repeat this with all your patches.
Now, RAM of your PC contains a modified firmware, which you apply to the phone by pressing 'Start' button. Wait until you see a message saying 'All done'.
Put back your MMC and SIM and start phone.
Enjoy!
I hope you understood everything and by the time I read your response your phone will be already patched.
M35 upravena -> MT50 tuned-> MC60 -> M55 fw10 ->fw11 ->fw91 (+patche) ->dead -> SX1 fw13 ->fw15 uk-de-ru ->fw15 uk-cz-sk + themes +1GB Pretec
For Blood is Life...
Gwin
0.84 SMM
PříspěvekZaslal: st květen 24, 2006 3:39 pm    Předmět: Odpovědět s citátem
2 diablo:Díky, že si to napsal. Teď na takové věci nemám vůbec čas.
Sameco
PříspěvekZaslal: út květen 30, 2006 8:35 pm    Předmět: Odpovědět s citátem
Thanks that was very useful but where I can get Admin mod pach that I could have themes on my sx1 Think
Sameco
PříspěvekZaslal: út květen 30, 2006 10:32 pm    Předmět: Odpovědět s citátem
I made that mod and I like ite Thanks you all
Sameco
PříspěvekZaslal: čt červen 01, 2006 9:11 pm    Předmět: Odpovědět s citátem
Diablo can you tel me how I can pach this pach to my sx1.
With what programs can I do that ? d'oh! http://siemensmania.cz/download.php?file=/patches/SX1/20_Free_10.5MB_RAM.zip[/list]
diablo
PříspěvekZaslal: st červen 07, 2006 12:04 pm    Předmět: Odpovědět s citátem
Well, I wouldn't really apply this particular patch, cause it will create a lot of free space in your memory, but on the other hand you will no longer be able to use the phone as a GSM device (no SMS, no calls, no internet)
The patch you're speaking about is useful for N-Gage games.
There are 2 different patch types for SX1. You apply them either via WSMP or Apacker. WSMP patches look like this
kód:
;patch XXX
replace:949849494:84848484
The rest is for Apacker. As far as I know, all the patches on Siemensmania are for WSMP.
N-gage patch is for WSMP. Make sure you copy Z:\SYSTEM\PROGRAMS\starter_arm.rsc to E:\SYSTEM\PROGRAMS\starter_arm.rsc
The patch includes 2 variant of starter_arm.rsc. One for normal use and one for extended memory, so its up to you which one you choose. To switch between these two modes, copy one of the starter_arm.rsc on your phone and restart.
Exclamation You canNOT call or charge your phone while in extended memory mode Exclamation
(Sorry for the delay, but I don't have internet connection at home and am working quite a lot)
Sameco
PříspěvekZaslal: st červen 07, 2006 8:36 pm    Předmět: Odpovědět s citátem
Big thanks diablo wink Smile
diablo
PříspěvekZaslal: út červenec 04, 2006 11:20 am    Předmět: Odpovědět s citátem
Sameco napsal:
You're welcome wink
