:: Zobrazit téma - SXG75 & EF81 Language "difference" BRD and Int
Odpovědět na téma    Obsah fóra -> Non Czech Languages Here
adfree
Založen: 10. 08. 2006
388.38 SMM
PříspěvekZaslal: út srpen 22, 2006 2:28 am    Předmět: SXG75 & EF81 Language "difference" BRD and Int Odpovědět s citátem
Because the AMSS.MBN (Firmware) is equivalent between BRD an International.
The Languagepacks must be found with BitPim!
At first. The T9 is in brew\shared\ldb
I have rename 722_DElsUN.ldb in 722_RUlsUN.ldb
Now I can use German words in T9 under Russian language. (I have both select Russian under Phone!)
Someone had so often asked for Norwegian...
Best Regards
ccd98
Založen: 31. 10. 2005
8031.04 SMM
PříspěvekZaslal: út srpen 22, 2006 9:53 am    Předmět: Odpovědět s citátem
Hallo,
I also noticed yesterday, that the file OEMT9common.udb is probably the T9 User Database, after comparing this file from my SXG and other EF81s.
(I thought earlier that this file could be some "script" responsible for writing with (in the case of SXG@FW22) diacritic, or without it (by EF81@FW48)).
So I´m very interested now, if the file 722_CSIsUN.ldb
in EF81@FW48 is different from the file in SXG@FW22.
I asked few owners of EF81 with this FW to send me this file - after copying it to their PC via SXG Komunikátor - but there are some problems with this app - it momentarily can´t copy files larger than (approx.) 30 kB.
Brick wall
But there´s an other possibility, too - that the file is completely the same like in my SXG and it contains words with diacritic and it depends on firmware, whether the diacritic will be applied.
I´m very afraid of this possibility... Think
OT: the character with two lions and two SXGs in avatar on modopo is me. 8)
S LXXV
adfree
388.38 SMM
PříspěvekZaslal: čt srpen 24, 2006 1:54 am    Předmět: Odpovědět s citátem
Tegic are found in these files, and they are the inventor of T9.
http://www.tegic.com/
It seems, that some of the T9 library from S75 works.
S75 has over 30 Languages... for T9.
I had only success with t9ru.ldb renamed in 722_RUlsUN.ldb
The difference: T9 from SXG75 Copyright © 2005 Tegic Comm.
S75 Copyright © 2003 Tegic Comm.
But I dont use T9, I'm to stupid to use it. Embarassed
Best Regards ccd98
adfree
388.38 SMM
PříspěvekZaslal: ne srpen 27, 2006 2:44 pm    Předmět: Odpovědět s citátem
Embarassed Brick wall
It seems harder to jump from LG03 to LG02... Brick wall
To change the Language Select menu:
kód:
brew\cfg\settings\display_languages
brew\cfg\settings\input_languages
Edit these files... For instance Norwegian is NO.
I think it is necessary to copy the corresponding T9 file 722_NOlsUN.ldb in brew\shared\ldb
Restart mobile.
kód:
Im so stupid... I forgot that 100 of [b]NO[/b] folders also to save... Where the Bar files are.
Best Regards
Odpovědět na téma    Obsah fóra -> Non Czech Languages Here Časy uváděny v GMT + 1 hodina
