alfah4ns badatel
 Založen: 06. 06. 2005 Příspěvky: 103
pip@ administrátor
Zaslal: pá prosinec 01, 2006 12:51 pm Předmět: patche pro S68 |
pár patchů pro S68
citace: | ; S68v47 lg4 - Patch made by "Smelter" © avkiev
;* Disable Aircraft Check * © Bennie
0265469: D1 E0
;* Change dialing ringtone "No connection" * © B-727
0DB3962: 1800FAFF0000B6034A0178054A0108074A01FFFFE803F9FF0300 0C00B8073200FFFF3200400C1A00FFFFFFFFFFFFFFFFFFFFFFFF
;* Decimal CID instead of C1 & C2 in neighbour list * © ńëŕâŕ Áîăó, ® SiNgle
0B91712: 0123F856002802DA 203FB88B203702E0
0B91720: 2B 20
0B91724: 02 05
0B9172E: 0223 0CE0
0D7B3A0: 31204332 656C4944
;* MyStuff = Disk Menu v0.1 * © cXastor (for MyStuff Creator program)
03FA17C: 0C0032003A005C0043007500730074006F006D00650072003400434E53495F435553544F4D45523500000C0032003A005C0043 040031003A005C0000007500730074006F006D00650072003400434E53495F435553544F4D4552350000040032003A005C0000
;*Change progressbar color* © -=(Kad)=-
0415974: BEE6FA64 5656F814 ; background
0415978: 1EBEE664 00000034 ; contour
041597C: 001E8264 FFFFFF24 ; stripe
;Disable keypad light* © SiNgle
07A1173: D5 24 |
_________________ Siemens: C35i, M35i, SL45i (aka U35), ME45 (aka Panther), C65 (aka Hera), M65 (aka X-cite), S75 (aka Minos), SG75 (aka Wolf4), SXG75 (aka Wolf5), EF81 (aka Kestrel)
alfah4ns badatel
Zaslal: so prosinec 02, 2006 12:22 pm Předmět: |
suupeer, hned jak budu mi dca110 tak du do toho  _________________ C35 --> M35i --> ME45 --> nokia 3510i (blééé) --> S55 + DCA-510 + 1,58MB+patche --> S68 + DCA-140 + DCA-110 |
pip@ administrátor
Zaslal: po prosinec 25, 2006 9:09 pm Předmět: |
tak co DCA-110?
už je i Elfloader + SWI + Funkční knihovny pro S68
http://www.siemensmania.cz/patche.php?phone=S68 _________________ Siemens: C35i, M35i, SL45i (aka U35), ME45 (aka Panther), C65 (aka Hera), M65 (aka X-cite), S75 (aka Minos), SG75 (aka Wolf4), SXG75 (aka Wolf5), EF81 (aka Kestrel)
t-lama kolemjdoucí
Založen: 23. 08. 2006 Příspěvky: 15
Zaslal: po leden 01, 2007 6:57 pm Předmět: |
Super, jen co se mi podaří předělat DCA-100 na servisni kabl, du do toho, jenom mi nejde otevřít ten rar co v něm je elfloader :'( |
pip@ administrátor
Zaslal: po leden 01, 2007 7:28 pm Předmět: |
tady je taky...
// tady na SM je to už opraveno _________________ Siemens: C35i, M35i, SL45i (aka U35), ME45 (aka Panther), C65 (aka Hera), M65 (aka X-cite), S75 (aka Minos), SG75 (aka Wolf4), SXG75 (aka Wolf5), EF81 (aka Kestrel)
Naposledy upravil pip@ dne po leden 01, 2007 7:34 pm, celkově upraveno 1 krát |
t-lama kolemjdoucí
Zaslal: po leden 01, 2007 7:30 pm Předmět: |
dík |
Lstiburek kolemjdoucí
Založen: 12. 09. 2006 Příspěvky: 3
Zaslal: st leden 03, 2007 3:49 pm Předmět: Co že je to taková "skey" ? |
Omlouvám se za svou negramotnost.
Telefon zatím používám především na telefonování.
Tahleta pomůcka (skey), ze které jste tak nadšení - to je dobré na co ?
Děkuji, že se mi smějete jen trochu a že mi třeba někdo dá ponaučení.
Luboš |
pip@ administrátor
Zaslal: st leden 03, 2007 3:59 pm Předmět: |
SKEY je kód, který když zavedete do telefonu, tak mu odemčete jeho skryté funkce, jako třeba servisní menu, otevře skryté disky (můžete měnit ikony menu) a hlavně umožní patchovat (upravovat SW telefonu..) a navíc je potřeba při odblokování telefonu... _________________ Siemens: C35i, M35i, SL45i (aka U35), ME45 (aka Panther), C65 (aka Hera), M65 (aka X-cite), S75 (aka Minos), SG75 (aka Wolf4), SXG75 (aka Wolf5), EF81 (aka Kestrel)
Pjootr všeználek
 Založen: 05. 08. 2004 Příspěvky: 656
Zaslal: st leden 03, 2007 4:22 pm Předmět: |
Tady jsou popsané klíče používané v PapuaUtils je tam i SKEY ->
http://www.siemensmania.cz/content.php?id=594 _________________ Nepřejte si znát můj inteligentní kvo kvo kvo kvo kvocient ...
alfah4ns badatel
Zaslal: po leden 08, 2007 4:23 pm Předmět: |
hhh,kablik dneska prisel, mno male zpozdeni, nakonec byl az po Vanocich....
kazdopadne vali to, takze ted prave se mi dela zaloha a hned jak se dodela tak patchuju....
EDIT:
tak sem pozkousel, classic red button, zrychleni klavesnice, cpu 208MHz, jemne podsviceni, ale pri swi-hook a elf loaderu mi prestal telefon cist *.txt soubory, este se na to zkusim pomrkat a trochu pokutit ;-) _________________ C35 --> M35i --> ME45 --> nokia 3510i (blééé) --> S55 + DCA-510 + 1,58MB+patche --> S68 + DCA-140 + DCA-110 |
Zaslal: st leden 10, 2007 5:44 pm Předmět: Díky za info |
Děkuji za informaci.
Zůstanu tedy raději jen u toho telefonování.  |
t-lama kolemjdoucí
Zaslal: st leden 10, 2007 6:54 pm Předmět: |
K tomu čtení .txt: radši si pořiď např. MicroReader, už je i pro nový siemense a umí narozdíl od předinstalovaný aplikace i diakritiku ;-) |
