Nueng kolemjdoucí
Založen: 05. 02. 2005 Příspěvky: 6
Zaslal: čt únor 17, 2005 9:06 am Předmět: Need schematic cable for flash X65 |
Need schematic cable for flash X65,SX1,SL55,.......New siemens Phone
SURE AND EASY!!!!!!!!!!!!!!
Please help me
Thank for your help |
wizaard táta fóra
Dieg0 siemensmaniak
19990.28 SMM
Zaslal: čt únor 17, 2005 9:14 am Předmět: |
I don´t have cable DCA510.I have only cable from CPA type: MA-8720-C. .Dieg0 _________________ ...odstraneno - prilis velky obrazek... |
Nueng kolemjdoucí
Zaslal: pá únor 18, 2005 10:30 am Předmět: |
Thank a lot
Thankzzzzzzzzzzzzzzzzzzz |
Nueng kolemjdoucí
Zaslal: pá únor 18, 2005 12:26 pm Předmět: |
the picture that you give me
It can use with SST,X65Flasher,winswup and XXX.Xbz?
I want want to use it with there
Flasher and upgrade firmware
should I install driver ? where download driver? |
jdobry rozumbrada
 Založen: 22. 01. 2005 Příspěvky: 381
Zaslal: pá únor 18, 2005 1:19 pm Předmět: cable schematics |
Add http://www.mobile-files.ru/forum/attachment.php?s=&postid=166938
This cable is eqivalent to DCA-540 cable with same limitation. This mean, that you can use only MCM software and oficial SW update.
Not exist way, how to use SST,X65Flasher,winswup, EEPROM tool and etc.
You must use DCA-510 cable for it, or MA-8730-C, or MA-8720-C with modification (disconnect pin 1 on connector, use switch) |
