kocica.karel badatel
100981.70 SMM
Posted: Thu Jan 29, 2009 3:17 pm Post subject: Nejde zapnout |
Dobrej, mám SXG75 a nejde mi zapnout, normálně nabíhá až po zadání PIN codu, zde jej zadám a následně telefon se kousne. Ale snaží se přihlásit do sítě, ruší rádio. Pokud odstraním PIN, tak vše se opakuje dle předchozího a to po potvrzení zapnutí telefonu. Díky za radu |
black brewmaster
 Joined: 01 Mar 2007 Posts: 490 Location: Slovensko Phone: SXG75 51754.60 SMM
Posted: Thu Jan 29, 2009 3:34 pm Post subject: |
Zapni mobil aby pýtal PIN. Potom chod cez BMC do brew/mod/idle/res/common/ a vymaž idle_common.bar
Keď to nepomôže, tak musíš prehrať sw.
Edit: este je 1 sposob od kraze
Quote: | Solution to reboot problem
Tools needed: DCA-540 cable, QXDM, file manger midlet
There's a problem (at least known on SVN26) when you receive a file by Bluetooth the fone may go sometimes to reboot. And then it reboots again and again.
The problem lies in incorrect handling of file brew\shared\alerts by idle application. The reboot doesn't happen if Orange Home Screen is enabled.
The file alerts is a database (again this problem with databases ) with missed events shown on mainscreen. If something happens to it (ocasionally it happens when a new file is received) the idle screen makes an error and sends the fone to reboot.
So the steps to follow if you don't want to reflash your fone:
1. get off your SIM-card, so the fone doesn't boot up completely
2. Use QXDM to activate Home Menu Enabled (set to 1) and set Home Menu to 0 (ORANGE_HOME_MENU) (see FAQ on it)
3. Boot up the fone completely with sim-card (it will boot up)
4. Use a file manager midlet (i.e. MiniCommander, MobyExplorer, Zeus 0.2 or Opera Mini Mod) to RENAME the file alerts in fs/
5. Now you must reboot the phone.
6. Now you can either set the idle screen to normal view (Settings>Display>Home Layout - Standard from the phone's menu) or continue to use orange home menu. The fone may reboot when switched from Orange to Standard. |
_________________ Siemens A55 fw 09
100981.70 SMM
Posted: Sat Jan 31, 2009 11:34 pm Post subject: |
Ahoj v prvu děkuji za odpověď. Jinak jsem soubopr pře BMC smazal a nepomohlo to. A tak jsem přistoupil ke druhé operaci a to přehrátí softu, ale také se nevede je tam hláška NEDOSTATEK PAMĚTI V MOBILNÍM TELEFONU NA PROVEDENÍ AKTUALIZACE. SMAŽTE PROSÍM PÁR ŘÁDKŮ Z MOBILNÍHO TELEFONU. Co s tím nevím volného místa .e 2291k |
100981.70 SMM
Posted: Sun Feb 01, 2009 12:46 am Post subject: |
Flash se povedl po smazání většiny vlasních souborů, ale stav se nezměnil, stále nejde zapnout. |
Luken badatel
 Joined: 26 Apr 2004 Posts: 158 Phone: mobilní 485.38 SMM
Posted: Mon Feb 02, 2009 4:14 pm Post subject: |
Dnes ráno se mi tostlo taky. Nechci to zakřiknout, ale pomohla customizace. _________________ Siemens C25 - C35 - M35 - C45 - C55 - S55 - S65 (na skok SE V630i) - SX1 - SXG75 - Benq-Siemens S68 - EF81 (3x) - SL75 a pak ANDROID
XPERIA X8, StarNote N9770, Lenovo P780 |
100981.70 SMM
Posted: Mon Feb 02, 2009 4:49 pm Post subject: |
Díky za odpověď, ale customizace znamená prosím co? Děkuji za vysvětlení.  |
GgDag siemensmaniak
 Joined: 03 Jul 2004 Posts: 3548 Location: Taliansko Mobil:HTC One
Posted: Mon Feb 02, 2009 6:59 pm Post subject: |
Customizaciou prehras komplet Filesystem . Ak som to zle napisal tak sry
Proste zmazes vsetko s mobilu vc. dat. Ale v 90% pripadoch to pomaha. |
100981.70 SMM
Posted: Tue Feb 03, 2009 9:13 am Post subject: |
Děkujii a byl by možný napsat nějaký postup, jak to udělat. Opravdu nevím a tu na fóru jsem to nenašel, jen vždy bylo napsáno, je potřeba udělat kustomizaci. Díky |
Luken badatel
Posted: Tue Feb 03, 2009 11:47 am Post subject: |
Mrkni se sem.
Code: | http://www.spssoftware.cz/?view=zabava/sxg75/opravasxg |
100981.70 SMM
Posted: Thu Feb 05, 2009 11:19 am Post subject: |
Děkuji o víkendu zkusím a s výsledkem jak to dopadlo se podělím. |
100981.70 SMM
Posted: Sun Feb 08, 2009 12:06 am Post subject: |
Ahoj, kde mám stáhnout
RF_NV_Manager.exe ?
Díky |
GgDag siemensmaniak
Posted: Sun Feb 08, 2009 12:01 pm Post subject: |
Nahraj si fw do pc a ked budes mat na vyber aktualizaciu FW a customizaciu tak nexaj len customizaciu a mas pokoj. |
100981.70 SMM
Posted: Wed Feb 11, 2009 1:04 pm Post subject: |
díky a jaký firmware máš na mysli a případně kde jej stáhnu? |
100981.70 SMM
Posted: Sat Feb 28, 2009 12:23 pm Post subject: |
Ahoj, díky kustomizace je hotova, telefon se zapne, ale nepřihlásí se do sítě. Co je třeba udělat, viděl jsem tu někde na fóru odkaz na opravu, ale nyní nemohu najít. Prosím o link |
mario_liptov administrátor
Posted: Sat Feb 28, 2009 12:35 pm Post subject: |
Hladaj topic o NVItems v tom je chyba. Musis ju obnovit. _________________ S6->N5110->N6110->S55->SE630->C65->CX65->C75->CX75->SX1->S65->ST55->SL65->S75->SL75->EF81->S68->EL71Black->EL71Silver->SXG75->C902->HTC Desire->SAMSUNG GALAXY SIII...?
