:: View topic - Problems with SXG75 prototype, need help.
Goto page Previous  1, 2
Straces
1013.16 SMM
PostPosted: Thu May 20, 2010 6:55 pm    Post subject: Reply with quote
Ok it will be good.
I have old amss dump from my SG75, there are some brew apps which arent in new phones (notes, calculator, curencyconverter..) but i wasnt successful to get it from dump :-(
If you want some new brew apps look at my website. But make dump before copy it and most of them are demos, without guarantees. And Shhh
MC60 -> CX65 -> SXG75 FW22 + IMS 700 + 2GB RS-MMC + DCA-110 + DCA-540 + pouzdro + BikeHolderkit..
Dell Axim x50v ( WM6.1 )
Siemens SG75 (FW 13.609.13)
Benq-Siemens SL91 (Onyx)
Benq-Siemens EF82
LG GW620 (Firedroid Mod 2.3.7)
kraze1984
155.88 SMM
PostPosted: Sun May 23, 2010 2:41 am    Post subject: Reply with quote
SXG75 SVN22\26 language reduced package as files backup.
english and hrvatsky languages only.
Just put the contents of archive to root of the mobile in BREW mode of BMC.
http://rapidshare.com/files/390532297/W5V0-22-26-EN_HR.rar
RedkinG
86269.90 SMM
PostPosted: Sun May 23, 2010 7:59 pm    Post subject: Reply with quote
Can I delete all files in root of phone? and then put this?
Because I think there are too many folders in root.
Siemens
A50, A55, A65
C45
ME45, MC60, M75proto
SL10, SL45i, SL55, S65, S68, SX1 Leather LE, SXG75proto, SL98proto
kraze1984
155.88 SMM
PostPosted: Mon May 24, 2010 11:35 pm    Post subject: Reply with quote
No, do not delete anything.
RedkinG
86269.90 SMM
PostPosted: Sat May 29, 2010 6:03 pm    Post subject: Reply with quote
...still same problems Crying or Very sad
Siemens
A50, A55, A65
C45
kraze1984
155.88 SMM
PostPosted: Mon May 31, 2010 4:29 pm    Post subject: Reply with quote
Strange...
Do you get your language in the menus?
RedkinG
86269.90 SMM
PostPosted: Mon May 31, 2010 4:32 pm    Post subject: Reply with quote
kraze1984 wrote:
Strange...
Yes, English and Croatian, but nothing else is working...
Siemens
A50, A55, A65
C45
kraze1984
155.88 SMM
PostPosted: Mon May 31, 2010 6:39 pm    Post subject: Reply with quote
Can you summarize, in what menus you cannot enter?
Messages, MyStuff, Games and that's all?
All other is working?
Phonebook is working? Extras, Calendar?
If so, then its definitely database issues...
In fact, Games should work anyways, whether the database is good or not.
I will think how I can solve this...
P.S. did you overwrite the folders contents in the phone? You should have done it.
144510.50 SMM
PostPosted: Sat Sep 15, 2012 9:05 pm    Post subject: Reply with quote
Mám teď úplně stejný problém jako Redking.
Jedno SXG (taky white, prototyp), po zapnutí najelo rovnou do Factory test módu. Tak jsem započal jeho SW rekonstrukci podle tohoto návodu. Jelikož byl rovnou v FTM, samozřejmě jsem přeskočil první dva body. Všechno jelo zdárně, soubory z root.rar jsem obnovil, jen
Sutrus v návodu wrote:
Spustit originalni FW26 a spustit nahravani.
toto jsem nesplnil a místo fw26 jsem použil fw22, protože ten jediný jsem tu našel originál (26 je flash update). NV items jsem bez problému obnovil. Na poslední bod
7. Spustit c:\Program Files\Siemens\3GSwupFU\StartUp.exe
jsem se vykašlal páč soubor Startup.exe v daném adresáři nemám (velmi pravděpodobně z důvodu použití fw22 a ne fw26). Po této proceduře telefon fungoval úplně stejně jako Redkingův a proto jsem ještě zkusil nahrát fw26, ale to zkončilo errorem a telefon po tomhle nezdaru zase najel jen do FTM. Tak jsem zopakoval celý postup až do obnovy NV items.
Takže mám prosbu Pray - mohl by mi někdo upnout někam originál update fw26 pro SXG Question Nebo je jiné řešení? Smile Udělat tu customizaci s fw22 jak jsem (nejsem si jist jestli správně Anxious ) pochopil nejde.
EDIT: Ono já bych to tak "prototypně" i nechal, ale mám tu víc než jeden kus tohohle SXG se stejným problémem a tak bych rád jedno zprovoznil na 100% Smile a už nechci sám (zbytečně) hazardovat s jeho prototypím životem Smile .
PostPosted: Sat Sep 15, 2012 10:17 pm    Post subject: Reply with quote
Ak mas taky isty problem tak mas smolu. Ten mobil sa neda spojazdnit. Smile
144510.50 SMM
PostPosted: Sat Sep 15, 2012 10:45 pm    Post subject: Reply with quote
Aha... no, tak budu rád že jede aspoň tak jak jede Very Happy (nejde media player, vlastní soubory a pokus o vyfocení fotky skončí hláškou "Failed to capture") Tak jak mi přišlo, nešlo nic, po zapnutí jenom najelo do toho Factory test mode.
Každopádně bych ten originál fw26 bral, mám tu ještě jedno SXG, taky proto, ale asi pozdější - black, které najede jenom na nápis SIEMENS.
PostPosted: Tue Sep 18, 2012 9:50 am    Post subject: Reply with quote
Pokial viem tak na prototypy treba flashovat FW urcene pre prototypy. Inac riskujes ze budes mat mrtvolku.
144510.50 SMM
PostPosted: Tue Sep 18, 2012 11:24 am    Post subject: Reply with quote
Jj, taky jsem měl obavy, ale když jsem se podíval na dalších 10 funkčních SXG prototypů co tu mám, které až na jeden mají fw 22 - 26, tak mě to přešlo Smile .
Page 2 of 2
