:: View topic - Patchovanie x65
Patchovanie x65
Goto page 1, 2, 3 ... 14, 15, 16  Next
Reply to topic     Forum Index -> Patche -> Články
PostPosted: Sat Oct 30, 2004 7:23 am    Post subject: Patchovanie x65 Reply with quote
Článek: http://www.siemensmania.cz/content.php?id=247
To tejto temy piste prosim poznatky z patchovania Siemensov x65,popripade nove patche a sposob patchovania.
Hned na uvod prispejem "trochou do mlyna" wink
Zainteresovani uz isto vedia,ze patchovanie x65 je trochu komplikovane. Dnes som sa docital na ruskom fore o dalsej moznosti. Je treba pouzit x65 Flasher a V_Klay 2.7.1.Tu je prelozeny postup:
Ako priklad pouzijeme patch pre aktivaciu servisneho menu na CX65:
;Enable Developer Menu CX65v16 (C)SiNgle
A09E2680: 04 08
- zalohujte si pomocou x65 flasheru kusok flashu z adresy A09E0000 s rozmerom 00020000.
- otvorte ho vo V_Klay
- skopirujte text patchu do okna V_Klay
- zmente zaciatok adresy v patchi na 00002680 (t.j. A09E2680 - A09E0000 = 00002680)
- aplikujte patch
- nahrajte pomocou x65 Flasheru kusok flashu naspat do telefonu na adresu A09E0000 s rozmerom 00020000
Tu je obrazok (komu je potrebny):
Preklad cervenych popiskov zhora dole:
Prepnut na pracu s fullflashom
Nechame nuly
Nahrajte kusok flashu
Zmente zaciatok adresy na 0000xxxx
PostPosted: Sat Oct 30, 2004 8:06 am    Post subject: Reply with quote
Patche S65 FW16:
Opened Discs Forever
CX65v16 (C)SiNgle
S65v12 (P)KiRiK
A101E3FC: 02 03
Setup Illumination By 2%
CX65v16 (C)SiNgle
S65v12 (P)KiRiK
A11F05D2: 0A 02
A11F05DC: 0A 02
S65 sw160100
A15C2B54: 02 03
Patche SL65 FW16:
CX65v16 (C)SiNgle
SL65v12 (P)KiRiK
A145B220: 02 03
Patche CX65 FW16:
A09E2680: 04 08
Opened Discs Forever CX65v16 (C)SiNgle
A1244CFC: 02 03
Setup Illumination By 2% CX65v16 (C)SiNgle
A0C3525A: 0A 02
A0C35264: 0A 02
Disable Keypad Light CX65v16 (C)SiNgle
A1002127: D5 24
Patche pre C65 FW16:
DevMenu:
00B61360 04 08
OpenDisk:
00B769F4 02 03
Keypad light:
00A5126B D5 24
illumination by 2%:
00C1A722 0A 02
00C1A72C 0A 02
Patche pre M65 FW16:
Dev. Menu:
A11A13E0: 04 08
Open Disk Forever:
A113382B: 02 03
Disable Keypad Light:
A14401BF: D5 24
Illumination by 2%:
A146EEAA: 0A3906D5002104E0011C0A 023906D5002104E0011C02
Illumination by 5%:
A146EEAA: 0A3906D5002104E0011C0A 053906D5002104E0011C05
Upozornujem,ze patche su len opisane z ruskeho fora a netestoval som ich! Testujte na vlastne nebezpecenstvo!!!
Grafic
PostPosted: Sat Oct 30, 2004 8:22 am    Post subject: Reply with quote
S65v16: (předělal Hamsa)
Open Disk: A15C2B54: 02 03
Illumination by 2%: A15E54FA: 0A3906D5002104E0011C0A 023906D5002104E0011C02
Illumination by 5%: A15E54FA: 0A3906D5002104E0011C0A 053906D5002104E0011C05
Je tam chybka. Udelal jsem ji, pac jsem to delal z *.fbk. Hamsa to dal do poradku:)
BEZY
81.16 SMM
PostPosted: Sat Oct 30, 2004 12:25 pm    Post subject: Reply with quote
2Hanni> hele nějak tohle nechápu:skopirujte text patchu do okna V_Klay Nechápu odkud ten text mam vzít? d'oh!
http://www.bezysoftware.net
Brew Mobile Commander 2.0
PostPosted: Sat Oct 30, 2004 1:06 pm    Post subject: Reply with quote
No ved som tam predsa v dalsom prispevku nakopiroval vsetky patche,co zatial su..no a to je ten text..napr.:
A14401BF: D5 24
ale treba pred vsetko,co nie je samotny patch dat ";" alebo to tam vobec nedavat.
Takze buď takto:
;Disable Keypad Light:
A14401BF: D5 24
alebo:
A14401BF: D5 24
Guest
PostPosted: Sat Oct 30, 2004 1:10 pm    Post subject: Reply with quote
MOhli by ste mi nekdo rict jak se dostanu do toho servisniho menu?
Predelel jsem si to na S65 ale nevim kde to hledat.Jak je to s DevMenu na M65 nebo na CX65?
Grafic
PostPosted: Sat Oct 30, 2004 1:12 pm    Post subject: Reply with quote
Prave taky nevim...Dev.Menu jsem nejak neobjevil...Sad
BEZY
81.16 SMM
PostPosted: Sat Oct 30, 2004 1:23 pm    Post subject: Reply with quote
Počkat to mi jako chcete říct že ikdyž aktivuju ten patch, tak se pak do toho menu nedostanu??? Tak proč se s tim teda dělám?
busch
27.84 SMM
PostPosted: Sat Oct 30, 2004 1:39 pm    Post subject: Reply with quote
SEM CHYTRÉÉÉJ
Po aktivaci patche se musí např. vytvořit položka v menu přes třeba x65fxCreator.
V developer menu je plno nastavení, serivsní menu, GPRS menu... Dancing
Nokia 6234, Ericsson T65
BEZY
81.16 SMM
PostPosted: Sat Oct 30, 2004 1:42 pm    Post subject: Reply with quote
busch wrote:
SEM CHYTRÉÉÉJ
Hele sorry, v tomhle sem amatér, ale jak se má vytvořit ta položka?
busch
27.84 SMM
PostPosted: Sat Oct 30, 2004 1:46 pm    Post subject: Reply with quote
BEZY wrote:
busch wrote:
SEM CHYTRÉÉÉJ
V tom x65fxCreatoru vybrat na nějakou pozici Development Menu. Na ostatní pozice můžeš dát cokoliv, ale něco tam dej, když sem dal jenom Development Menu tak to házelo menu error.
Sice to asi nebude souhlasit s ikonama co teď v menu máš, ale na vyzkoušení to stačí...
PostPosted: Sat Oct 30, 2004 2:09 pm    Post subject: Reply with quote
A nejde vybrat Developer menu na nejake tlacitko,ako rychla volba?
BEZY
81.16 SMM
PostPosted: Sat Oct 30, 2004 2:20 pm    Post subject: Reply with quote
JDE TO! V DSE jsem si to nastavil jako 1. položku v My Menu, teď zkusim jestli to fachčí
busch
27.84 SMM
Jo teď sem to zkusil a mám ho vybraný na podržení joysticku Dancing
BEZY
81.16 SMM
PostPosted: Sat Oct 30, 2004 2:25 pm    Post subject: Reply with quote
Tady je obsah Developer menu: (S)Exit;Java;Overlay Config;Configuration;Native menu;LOGAL;DRM rec.Rights
A deme si hrát
Reply to topic     Forum Index -> Patche -> Články All times are GMT + 1 Hour
Page 1 of 16
You cannot attach files in this forum
You cannot download files in this forum
