Ostane zaruka? |
Ano |
85% |
[ 12 ] |
Nie |
14% |
[ 2 ] |
Total Votes : 14 |
Putcha badatel
 Joined: 21 May 2005 Posts: 100 Location: Bratislava, Slovakia
Posted: Sat Jun 04, 2005 5:13 pm Post subject: Cisto teoreticky |
Som novacik a tak som uvazoval jak tam nastrkat patche a neprist o zaruku a prisiel som na toto, len neviem ci to tu zaruku nezrusi.
Urobim si FF. Nastrkam tam patche. Popr umrtvim telefon. Ked mi niaka HW cast odide, dam tam ten moj FF a vsetko bude ako pred aplikovanim patcjov.
Co si myslite, ostane zaruka, alebo pridu na to? |
Whitek administrátor
41313.42 SMM
Posted: Sat Jun 04, 2005 5:21 pm Post subject: Re: Cisto teoreticky |
Putcha wrote: | Som novacik a tak som uvazoval jak tam nastrkat patche a neprist o zaruku a prisiel som na toto, len neviem ci to tu zaruku nezrusi.
Pokud ten telefon bude schopny FF prijmout, tak to asi nepoznaji _________________
lacibogi čestný člen
Posted: Sat Jun 04, 2005 5:23 pm Post subject: |
Zaruku stratis, ale nahratim FF oni na to nepridu. Takze ako keby si ju ani nestratil. _________________ C(ME)75
Lasky |
Putcha badatel
Preco by nebol schopny ho primat, ked to bude moj vlastny FF, alebo myslis, ked bude umrtveny?
Ked tam dam FF, tak ake datumy tam budu? |
41313.42 SMM
Posted: Sat Jun 04, 2005 5:32 pm Post subject: |
Putcha wrote: | Preco by nebol schopny ho primat, ked to bude moj vlastny FF, alebo myslis, ked bude umrtveny? |
Kdyz bude natolik mrtvy, ze tam puvodni FF nedas, tak na to dost mozna prijdou... _________________
Putcha badatel
Posted: Sat Jun 04, 2005 5:35 pm Post subject: |
A co s tymi datumami Quote: | Ked tam dam FF, tak ake datumy tam budu? |
Posted: Sat Jun 04, 2005 5:37 pm Post subject: |
Putcha wrote: | A co s tymi datumami Quote: | Ked tam dam FF, tak ake datumy tam budu? |
Mam skusenost ze im to vobec nevadi. Neviem ci sa datumy pomenia alebo co sa s nimi stane. Kamaratovi som nahral jeho zalohu vyreklamoval u T-Mobilu a hotovo. _________________ C(ME)75
Lasky |
Putcha badatel
Posted: Sat Jun 04, 2005 5:44 pm Post subject: |
Lb01 wrote: | Putcha wrote: | A co s tymi datumami Quote: | Ked tam dam FF, tak ake datumy tam budu? |
Mam skusenost ze im to vobec nevadi. Neviem ci sa datumy pomenia alebo co sa s nimi stane. Kamaratovi som nahral jeho zalohu vyreklamoval u T-Mobilu a hotovo. |
No hej u T-mobile, ale co ked to rovno odnesem do siemensu. |
szkepek táta fóra
Joined: 17 Jan 2005 Posts: 1269 Location: Konice - největší prdel na jih od Arktidy a na Sever od Sahary
Posted: Sat Jun 04, 2005 5:46 pm Post subject: |
No a co tak nahrat FF napr. 25 a pak si tam dat originalni FW43 ? Na to sice prijdou, ale nic ti nemuzou, protoze originalni FW tam muzes dat i v zaruce, ne  _________________ Vita Circulus ést !!! |
Putcha badatel
Posted: Sat Jun 04, 2005 5:54 pm Post subject: |
szkepek wrote: | No a co tak nahrat FF napr. 25 a pak si tam dat originalni FW43 ? Na to sice prijdou, ale nic ti nemuzou, protoze originalni FW tam muzes dat i v zaruce, ne  |
Ale to sa potom zmeni FFS, ja potrebujem to moje. |
Bonfire čestný člen
Příspěvky na SM: 110,- |
Posted: Sat Jun 04, 2005 6:07 pm Post subject: |
kdyz bude natolik HW mrtvy ze tam nebudes moct nahrat zalohu FF, tak ani oni nezjisti jestli je telefon patchovany nebo ne _________________ C1,C2,C3,C4,C5,P1,S3,S3plus,S3com,S4,S6,S8,C10,E10,S10,S10active,SL10,U10,S15,C25,C28,S25,C30,M30,A35,A36,C35,M35,S35,S40,S42,
szkepek táta fóra
Posted: Sat Jun 04, 2005 7:46 pm Post subject: |
Putcha wrote: | szkepek wrote: | No a co tak nahrat FF napr. 25 a pak si tam dat originalni FW43 ? Na to sice prijdou, ale nic ti nemuzou, protoze originalni FW tam muzes dat i v zaruce, ne  |
No podle me to s FFS vubec nesouvisi.  _________________ Vita Circulus ést !!! |
Posted: Sat Jun 04, 2005 8:24 pm Post subject: |
Tak to uzavriem...
Ako tu uz bolo napisane mnohokrat,staci si pred patchovanom urobit zalohu FF a mozes patchovat kolko chces...a nejakymi datumami a casmi sa vobec nezatazuj  _________________ Kdo umí, ten umí. Kdo neumí, ten čumí. |
Putcha badatel
Posted: Sat Jun 04, 2005 8:35 pm Post subject: |
OK.Diki moc vsetkym. |
maskot pisatel
Posted: Sun Jun 05, 2005 12:08 pm Post subject: |
Putcha wrote: | Lb01 wrote: | Putcha wrote: | A co s tymi datumami Quote: | Ked tam dam FF, tak ake datumy tam budu? |
Z T-Mobile to putuje do toho isteho servisu ako zo Siemensu (Inoteska), takze to je v podstate jedno...
Ja som u TM reklamoval, dal som tam FF z novembra 2004 a nevadilo im, ze nic novsie tam nie je... _________________ Motorola T2288 -> A50 -> CXT65 fw. 16 -> fw. 25 -> fw. 36 -> fw. 25 -> fw. 43 -> fw. 50 + patch na 14,74MB (odstraneny) -> prerobeny na CX70 fw. 56 |
