:: View topic - Divná hláška při pokusu o flašnutí v-klayem - co s tím?
Reply to topic     Forum Index -> Odblokování
Lepar
PostPosted: Sun May 08, 2005 11:58 am    Post subject: Divná hláška při pokusu o flašnutí v-klayem - co s tím? Reply with quote
Pri pokusu o flashnuti umrtveneho telefonu se ojevi hlaska: A HARDWARE I/O ERROR WAS REPORTED WHILE ACCESSING COM1 - LOADER : OPEN : NO ANSWER FROM BOOT INITBOOT.BIN. a pak uz to nic nedela... Nevite co s tim???
capo di tutti capi
PostPosted: Sun May 08, 2005 12:05 pm    Post subject: Reply with quote
Loader Exclamation Exclamation Exclamation
Buď múdrejší ako sú ostatní, ale nepovedz im to
Lepar
PostPosted: Sun May 08, 2005 12:13 pm    Post subject: Reply with quote
NO a co s tim loaderem mam delat????
capo di tutti capi
PostPosted: Sun May 08, 2005 12:19 pm    Post subject: Reply with quote
jaky mas telefon? fw?
Lepar
PostPosted: Sun May 08, 2005 12:36 pm    Post subject: Reply with quote
no v tom je prave problem. byl tam nejaky originalni, ten jsem se snazil prehrat na novy stazeny z vasich stranek,ale nejak se to nepovedlo no a pak jsem se tam pokousel nahrat ten co mate na webu u v-klaye u toho navodu na oziveni mrtveho telefonu, ale ten uz tam nesel, protoze to napsalo tu hlasku...
capo di tutti capi
PostPosted: Sun May 08, 2005 12:43 pm    Post subject: Reply with quote
ale aky mas telefon?
Lepar
PostPosted: Sun May 08, 2005 1:58 pm    Post subject: Reply with quote
ha. to jsem zapomnel napsat. Je to A50tka
PostPosted: Sun May 08, 2005 2:16 pm    Post subject: Reply with quote
A aky FW?Nie nahodou 11 alebo 12?
Lepar
PostPosted: Sun May 08, 2005 4:30 pm    Post subject: Reply with quote
no ten co jsem tam chtel puvodne nahrat byl 11 a pak 12, ale ty nesly no a tim temer skoncilo,protoze jsem tam pak zacal nahravat ten co je pro vklay - a50fullflash, ten sel, zacalo se to nahravat a pak mi ten program spadnul. no a potom pri jakekoliv dalsi snaze to spustit mi to napsalo tu hlasku, kterou ted resim...
Reply to topic     Forum Index -> Odblokování All times are GMT + 1 Hour
