Adam Bernat začátečník
Založen: 07. 07. 2004 Příspěvky: 38
Zaslal: st květen 18, 2005 8:06 pm Předmět: Ako pozerat obrzky na SL45i |
Newie nahodou niekto ako by som si mohol pozerat obrazky na SL45i bez toho aby som si musel kazdy jeden osobitne natawit,pozret,atd.
Ci nemate niaky ten programik.
A nahodou daka www page na java aplikacie? =P~ |
truhlik elfmaster
 Založen: 11. 08. 2004 Příspěvky: 405 Bydliště: Praha
8069.50 SMM
Zaslal: st květen 18, 2005 9:47 pm Předmět: |
muzes zkusit tohle
;*** BFP. Bitmap File Preview v1.1 ***
;Firmware : SL45v56
;Author : rizapn
;Created : July 29, 2004
;Updated : Aug 1, 2004 (v1.1)
;Give a capability to preview the bmp file before using it as an operator logo
;v1.1->correct a "delete previous bitmap logo" bugs
0x02D5C0: E6FCBB00 DB00CC00
0x3874E2: E6F61D00 DAE4C049
0x38CD46: DAE638F1 DAE4DA49
0x4449C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6F44828E0C5E6FB2000E00AE6F38001
0x4449D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DAC70AEEE6F61D00DB0088908880E6FD
0x4449E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 5028E0CE88E088D026FD0800E6FC214E
0x4449F0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DAC1543F0804E6FC5AF5E6FDD800E6FE
0x444A00: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 96F5F0FDDAF03CFDF084F095F0C8F0D9
0x444A10: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FE4E0AE6FF9103DAF024FFFADBBC70
0x444A20: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DC4FD44E020046F41F002D0CE004E6F5
0x444A30: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2000E6FA4828E0CBE6F38001DAC70AEE
0x444A40: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FAE64EF6E6FCBB00DAA2C4D50DF90000
0x444A50: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0000204AE40000000000D849E400DA3D
0x444A60: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E302BA3DE2020000080065002F00780A
0x444A70: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 9103000000000000214EFFFFFFFFFFFF
;yes, it is rather dirty, but work without any known bugs...
a pokud to neni to pravy, tak existuje jeden java program, nevim presne jak se jmenuje, asi BIG EYE (EAGLE EYE, ONE EYE) proste tak nejak a ten zobrazuje i velkyobrazky, muzes vnich skrolovat atak:)snad i videa prehrava,
tak ted sem se ti koukal, je to BIG EYE
jo a naky java programy mam na strankach, http://sl45i.wz.cz/
OT: jo a kdyz uz tam budes, muzes mi kliknout na banner s operou, zucastnil sem se affiliate programu od Opery ASA a pokud sezenu dostatecnej pocet klikancu, tak mam registraci zdarma. porad mi chybi dost tak muzes udelat dobrej skutek:) |
Zaslal: čt květen 19, 2005 8:41 pm Předmět: |
a niake hry by sa nenasli.
wies,ked je nuda co narbis. |
truhlik elfmaster
8069.50 SMM
Zaslal: čt květen 19, 2005 10:04 pm Předmět: |
hele ty, koukal si se vubec na tu stranku na download ty java databaze?
ma priblizne 13 MB, a URCITE v ni nejaka hra je, staci jen stahnout a rozbalit:) tak to zkus a pak se teprv ptej:) |
Seten ostřílený diskusník
Založen: 06. 10. 2004 Příspěvky: 594 Bydliště: Brno
3061.00 SMM
Zaslal: so květen 21, 2005 4:06 pm Předmět: |
Myslim ze uz bo ten patch aj verzia 2.
Ak chces truhlik nejake hry tak ti poslem celu moju byvalu zbierku. _________________ SX1 , SL45i, SL45i. |
Zaslal: so květen 21, 2005 9:30 pm Předmět: |
Asi tak ze som stiahol aj tu javu a este zopar inych weci ale rozbalit to wobec nejde.
No a Seten ak mozes tak psli daco.
Dik moc. |
3061.00 SMM
Zaslal: so květen 21, 2005 9:52 pm Předmět: |
Adam Bernat napsal: | Asi tak ze som stiahol aj tu javu a este zopar inych weci ale rozbalit to wobec nejde.
Dik moc. |
Poslem ti zajtra ink kde si to moze vsetko stiahnut _________________ SX1 , SL45i, SL45i. |
Bonfire čestný člen
Příspěvky na SM: 110,- |
Zaslal: ne květen 22, 2005 9:18 am Předmět: |
vsak pockejte na SL45i tuning - tam to je, a taky jeste hafo dalsich patchu co ani nejsou na CZ serverech.. _________________ C1,C2,C3,C4,C5,P1,S3,S3plus,S3com,S4,S6,S8,C10,E10,S10,S10active,SL10,U10,S15,C25,C28,S25,C30,M30,A35,A36,C35,M35,S35,S40,S42,
3061.00 SMM
Zaslal: ne květen 22, 2005 10:01 am Předmět: |
http://www.sl45i.meeen.net/
Jeden taky dobry programik, ktory je robeny priamo na SL45i. _________________ SX1 , SL45i, SL45i. |
