:: View topic - z foto čb obrazok do sl45i
Reply to topic     Forum Index -> x62 a starší řady -> x45
Adam Bernat
PostPosted: Tue Jun 07, 2005 5:38 pm    Post subject: z foto čb obrazok do sl45i Reply with quote
nazdarek.
nema tu nahodou niekto z was taky ten programik do ktoreho dam fotecku a on mi z nej urobi čb obrazok a potom to dam len to mobilu.
alebo sa to da aj w skicari?asi nie,co?
Bonfire
Phone: HTC HD2
9259.32 SMM
PostPosted: Tue Jun 07, 2005 5:54 pm    Post subject: Reply with quote
myslim ze PaintShopPro by to mel zvladnout, tak sem to kdysi delal ja...
Koupím Siemens, který nemám.
PostPosted: Tue Jun 07, 2005 7:22 pm    Post subject: Reply with quote
To zvladne hociaky graf. editor...len zmenis farebnu skalu na 2bit
Adam Bernat
PostPosted: Wed Jun 08, 2005 6:36 pm    Post subject: Reply with quote
no a ked to mam sprawene tak bych to rad dal na welkost loga bo je to welke.a ak?bo ake su rozmery?
SlovakSoft
(člen klubu SM)<br>začátečník
PostPosted: Wed Jun 08, 2005 9:11 pm    Post subject: Reply with quote
No, ja mam vlastne robene logo velkosti 100x40. A na taketo upravy postaci IrfanView.
EF81
Reply to topic     Forum Index -> x62 a starší řady -> x45 All times are GMT + 1 Hour
