:: View topic - Problem with SieFS
Problem with SieFS
Paool
PostPosted: Sat Jun 18, 2005 11:32 am    Post subject: Problem with SieFS Reply with quote
Hi there Very Happy
I have fuse 2.2.1 module in kernel, compiled SieFS 0.5 and when I mounted my CX65 it doesn't wrok Sad (no errors while mounting)
Code:
sudo mount -t siefs /dev/ttyS0 /media/mobile
It creates a file, which I can't open Sad
anyone know what I should do?
Siemensinfo.pl
circulus
PostPosted: Sat Jun 18, 2005 2:32 pm    Post subject: Reply with quote
Hi,
try this as root user:
Code:
mkdir -m 0777 /media/mobile
or
Code:
chmod 0777 /media/mobile
and after this, try mount mobile as a normal user.
-m 0777 parameter sets permissions on directory /media/mobile to read,write and "browseable" for everyone.
C25->C35i(fw18 with T9CZ!)->C45->C55->M55->C65 fw50(patched)->SE K510i->N70->K320i->Huawei Sonic.
jabber: circulus[at]njs[dot]netlab[dot]cz
Paool
PostPosted: Sat Jun 18, 2005 3:18 pm    Post subject: Reply with quote
that didn't change anything... Sad
Siemensinfo.pl
circulus
PostPosted: Sat Jun 18, 2005 5:20 pm    Post subject: Reply with quote
Hmm, I don't have problem with SieFS. Post here output from command
Code:
ls -l /media
and output from command
Code:
dmesg ¦ tail
after doing a mount command
This seems to be like that /media/mobile is an file instead a directory.
Paool
PostPosted: Sat Jun 18, 2005 6:11 pm    Post subject: Reply with quote
Code:
paool@ubuntu:~$ ls -l /media
ls: /media/mobile: Brak dostępu
razem 12
lrwxrwxrwx  1 root root    6 2005-06-16 20:28 cdrom -> cdrom0
drwxr-xr-x  2 root root 4096 2005-06-16 20:28 cdrom0
lrwxrwxrwx  1 root root    7 2005-06-16 20:28 floppy -> floppy0
drwxr-xr-x  2 root root 4096 2005-06-16 20:28 floppy0
drwxrwxrwx  9 root root 4096 1970-01-01 01:00 windows
no access to /media/mobile
Code:
paool@ubuntu:~$ dmesg ¦ tail
Usage: dmesg [-c] [-n level] [-s bufsize]
Question
Siemensinfo.pl
circulus
PostPosted: Sat Jun 18, 2005 6:32 pm    Post subject: Reply with quote
Hmmm, mount point must be an directory (and you have none in /media), so that correct procedure is (as root user):
Code:
mkdir -m 0777 /mnt/mobile
mount -t siefs /dev/ttyS0 /mnt/mobile
After this, the mobile files are in /mnt/mobile .
This must work, but only for root user.
Paool
PostPosted: Sat Jun 18, 2005 7:02 pm    Post subject: Reply with quote
it's still the same... Sad
Siemensinfo.pl
circulus
PostPosted: Sat Jun 18, 2005 7:50 pm    Post subject: Reply with quote
I don't know much more how to advice with your problem. I have tested siefs 0.50 with FUSE 2.3.0 on Fedora Core 2 and Fedora Core 3 without problem.
You may also try this command as root :
Code:
fusermount /mnt/mobile siefs /dev/ttyS0
There are link to download files of fuse project http://sourceforge.net/project/showfiles.php?group_id=121684&package_id=132802
Functionality of siefs depends on correct order of compilation. First must be compiled and installed fuse (and fuse-dev package, if exist in Ubuntu) and then is possible to compile and install siefs.
Try use a version 2.3.0 of fuse. Now I will be offline (I am going to take some beer, because Saturday night begins Very Happy )
Paool
PostPosted: Sat Jun 18, 2005 7:58 pm    Post subject: Reply with quote
paool@ubuntu:~$ sudo fusermount /mnt/mobile siefs /dev/ttyS0
Password:
fusermount: old style mounting not supported
Actually I've tried 2.3.0 version of fuse but... the same Neutral
In other distros I don't noticed this problem Confused
yeah, me too Twisted Evil
Siemensinfo.pl
Guest
PostPosted: Sat Jul 02, 2005 3:23 pm    Post subject: Reply with quote
i have fuse 2.3.0, siefs 0.5 and it doesn't work Sad
Code:
root@tweety:~# mount -t siefs /dev/ttyUSB0 /mnt/siemens/
mount: unknown filesystem type 'siefs'
i really don't know what is wrong it SHOULD work but it doesn't
Borix
veterán
veterán
PostPosted: Sun Jul 03, 2005 2:25 pm    Post subject: Reply with quote
You can read this:
http://www.beinspired.cz/index.php?s=info/ostat/8/&clanek=839
I know that it is in czech language but you can understand something from the pictures.
Opty
PostPosted: Sun Jul 03, 2005 8:11 pm    Post subject: Reply with quote
cesky umim jen sem nechtel kazit thread Very Happy
ten navod je moc hezkej ale to sem samozrejme udelal uz davno pred tim Smile mozna je problem v tom ze to zkousim pod jadrem 2.6.x misto 2.4.x jak pisou na strankach siefs ale na netu sem nasel cloveka co to provozuje pod 2.6.11.11 a v pohode... dokonce sem zkousel i fuse 2.2 ale nic Sad
no jak budu mit casu tak to pro jistotu testnu s 2.4.x a jestli to pujde tak me to paradoxne nastve Sad
Linux is like a teepee -- no windows, no gates, Apache inside!
circulus
PostPosted: Mon Jul 04, 2005 11:00 am    Post subject: Reply with quote
No ono to chodí i pod jádry 2.6.x . Možná je na vině ještě ta "bezvadná věc" udev. Nevím to jistě, ale fuse si možná musí vytvořit nějaké položky v /dev a pokud se použije udev a není správně nakonfigurované tak to fuse nejede. Nějaký takový menší problémek jsem s tím měl na Fedora Core 3, ale už nevím co to bylo přesně, avšak povedlo se to rozchodit. Teď budu doma instalovat FC4 tak uvidím co se bude dít.
Opty
PostPosted: Mon Jul 04, 2005 8:30 pm    Post subject: Reply with quote
to by mohlo byt ono to me nenapadlo Smile i kdyz ted sem nedavno udev odinstaloval a taky to myslim neslo ale asi by to chtelo jeste zrevidovat
pokud to nepujde tak uz nevim dneska sem to zkousel na 2.4.x a ta sama chyba... takze jadrem to neni... no uvidime dik za tip
Opty
PostPosted: Mon Jul 04, 2005 8:51 pm    Post subject: Reply with quote
tak udev to neni Sad v /dev mam
Code:
crw-------  1 root root 10, 229 2005-06-09 22:40 /dev/fuse
a stejne nic nejde
btw kdyz pripojim telefon a pouziju slink i tak mi to neco vypise a pak uz nic...
EDIT: uz mi to konecne funguje...! Smile mnou vytvoreny balicek pro slackware 10.1 totiz neobsahoval symbolicky odkaz /sbin/mount.siefs na siefs ktery se sice pri make install vytvori ale pokud clovek pouzije DESTDIR tak ne v adresari balicku
