:: View topic - Connection failure
Connection failure
Buldi
PostPosted: Sun May 22, 2005 10:15 am    Post subject: Connection failure Reply with quote
Moj Siemens CX65 sa nechce pripojit na PC ani pomocou SiMoCo ani pomocou Siemens Data Exchange Software. Pouzivam kabel "asi" RS-232 ani poriadne neviem. Ale pri mojej SL55ke bolo spojenie vzdy super. Je chyba v kabli alebo v telefone? Ze by boli nekompatibilne? Please help, tak strasne rad by som sa zbavil tych odpornych Orange ikon Twisted Evil ! Diky Dancing
1shark1
3061.00 SMM
PostPosted: Sun May 22, 2005 10:17 am    Post subject: Reply with quote
asi budeš muset předělat kabel(jestli je to DCA- 500)
Siemens CX65 FW50 + Carged Plasma
serzino
PostPosted: Sun May 22, 2005 10:20 am    Post subject: Re: Connection failure Reply with quote
Zapoj kabel do fonu stlac *#06# info a na spodku mas prislusenstvo.Skontroluj ci ti fon poznal kabel ci tam mas nieco napisane napr:Dca500,alebo none. Think
Guest
PostPosted: Sun May 22, 2005 3:05 pm    Post subject: Re: Connection failure Reply with quote
Nuz nic tam nie je tak predpokladam ze ho nespoznal... asi treba iny kablik, hmm vsak? Think
1shark1
3061.00 SMM
PostPosted: Sun May 22, 2005 4:36 pm    Post subject: Reply with quote
DCA 510 wink
