Quattrop kolemjdoucí
Posted: Wed Jun 01, 2005 5:37 pm Post subject: Nedari se upgrade A55 na C55 |
Mam problem s predelanim Siemense A55 na C55. Firmware 9. Freia ani V_Klay, EEPROM Tool se s telefonem nedokaze spojit. Freia vypisuje:
FREIA - Engine build 15, Frontend build 11
Thanks goes out for the following:
Maxim, Rolis, Sergey, PapaJoe, Lead,
TheWizard, Jozso (for hardware and cable
support and of course beta testing),
Nico, Pinker, Tom, Crew
and all the others who supports ...
COMM_LoadBoots : selected phone family is 8
TTY_OpenCOMPort : opening Prodigy
TTY_OpenCOMPort : cannot open Prodigy
COMM_IsBootRunning : bootcode does not seem to be running
COMM_LoadBoots : Waiting to power on the phone ...
COMM_LoadBoots : phone is not powered on
TTY_CloseCOMPort : Closing Prodigy
Tlacitko zapnuti kratce zmacku!!! Nepodarilo se mi to ani s orig. kabelem (to by stejne nemelo), ale objednaval jsem i USB kabel z www.datovekabely.com, ktery ma umet odblokovat apod. Takze predpokladam, ze s tim by to uz jit melo. Nevim, jak ten kabel vyzkouset, jestli to frci. Je nejaky program, ktery slouzi treba jen pro stazeni adresare ze Siemensu A55, abych overil, ze ten kabel aspon nejak funguje? Cim jinym nez kabelem by to mohlo byt? Nevim, jestli to ma testpoint, nemuzu se dostat do telefonu, ale u firmwaru 9 snad jeste nebyl...
Diky za odpovedi, Quattrop |
Bond čestný člen
 Joined: 11 Dec 2004 Posts: 3289 Location: Hradec Králové
14861.00 SMM
Posted: Wed Jun 01, 2005 6:11 pm Post subject: |
a co ti to napise ve v_klay ve freie se nevyznám. |
Posted: Wed Jun 01, 2005 6:34 pm Post subject: V_Klay |
uz si nepamatuju co to pise, ale mam takovy tuseni, ze proste nic. Snazi se spojit a spojit a..... a nic se nestane. Nepripoji se. |
petrkaminek kolemjdoucí
Posted: Tue Jun 21, 2005 5:47 pm Post subject: |
SKus 1. verziu prerabky A55 na C55.Tam nie je nutne spajat sa s Freiou a V_Klay. _________________ Kdo umí, ten umí. Kdo neumí, ten čumí. |
cooler5 ostřílený diskusník
3061.00 SMM
Posted: Tue Jun 21, 2005 6:45 pm Post subject: |
Určite je chyba v kábli alebo v USB porte.... mne sa to s tou friou podarilo na prvýkrát aj som ho prerobil.... mne to tiež nešlo ale, zistil som, že mám zlé USB a v tom bol problém... |
havros badatel
Posted: Wed Jun 22, 2005 4:04 pm Post subject: Nastavení |
V nastavení Freii nastav Bootcore Bug a ne Normal. Mohlo by to pomoct |
Bohaty kolemjdoucí
Posted: Fri Jul 22, 2005 6:58 am Post subject: mě to taky nejde |
mám naprosto stejný problém, Freia mi píše to samé, nezávisle na tom jestli použiju neoriginální nebo originální kabel (půjčený od kolegy, kterému se S55 plně funguje), mám nastavené rychlosti, bootcore bug... znáte někdo řešení? |
haldyr řád zlaté antény
 Joined: 30 Aug 2004 Posts: 866 Location: Červ. Kostelec (Naith Lothlórien)
Posted: Wed Jul 27, 2005 7:01 pm Post subject: Re: mě to taky nejde |
Bohaty wrote: | mám naprosto stejný problém, Freia mi píše to samé, nezávisle na tom jestli použiju neoriginální nebo originální kabel (půjčený od kolegy, kterému se S55 plně funguje), mám nastavené rychlosti, bootcore bug... znáte někdo řešení? |
Jakej přesně kabel? Idealní je DCA-510. _________________ 5110>>>C55 FW21>>>C55 FW24 888KB, 245KB HpM + patche>>>CX75 + RS-MMC 256MB Pretec + Headset with PTT Stereo(HHS-700) |
Bohaty kolemjdoucí
Posted: Thu Jul 28, 2005 7:02 am Post subject: už mám C55 !! |
Díky za reakci, už se mi to podařilo.
Chyba byla v kabelu, objednal jsem si ho u stejné firmy jako autor úvodního příspěvku (www.datovekabely.com), je evidentně nefunkční, snad je to jen vadný kus a ne vlastnost všech jimi dodávaných kabelů :o . Každopádně na můj dotaz na vstřícný způsob řešení reklamace jejich vadného kabelu byli velmi sarkastičtí. Tento týden ho zašlu na reklamaci. |
Posted: Wed Sep 21, 2005 11:37 am Post subject: byl to kabel |
Po delsi dobe jsem si vzpomnel, ze jsem sem zapomnel napsat jak to dopadlo. Bylo to tim USB kabelem z www.datovekabely.com. Podarilo se mi ho poslat zpet vcas tak, aby mi vratili prachy. Pak jsem koupil uz pro jistotu obyc. COM kabel z kabelmanie a uz to slo v pohode ;-) |
Bohaty kolemjdoucí
Posted: Thu Sep 22, 2005 7:14 am Post subject: zrejme super firma |
Jo, ja jsem ho taky vyreklamoval a koupil si orig.Siemens kabel a jsem taky v pohode. Tak bacha na datovekabely.com ! |
