:: View topic - Software update denied by mobile
dlepka
PostPosted: Tue Jul 05, 2005 10:54 am    Post subject: Software update denied by mobile Reply with quote
Tuhle hlasku mi to vypisuje pri nahravani FW cez WinSwup. Co s tím? Ted stahuju FW 54 na CX 70 tak snad to pujde...
PostPosted: Tue Jul 05, 2005 10:56 am    Post subject: Reply with quote
A z akeho na aky FW prechadzas?
dlepka
PostPosted: Tue Jul 05, 2005 11:00 am    Post subject: Reply with quote
Idem z FW 50 na FW 25 (všetko WinSwup) aby som tam mohol hodiť oficiálnu 43.
PostPosted: Tue Jul 05, 2005 11:08 am    Post subject: Reply with quote
Aha,hned som si to myslel.Mas v bootcore telefonu nastaveny tovarensky FW vyssi ako je FW25...takze FW25 tam nenahras.
Guest
PostPosted: Tue Jul 05, 2005 11:09 am    Post subject: Reply with quote
Vďaka!
