:: View topic - Doesn't work siemens tiuning fw 43 links
Dowisss
PostPosted: Sat Aug 13, 2005 3:25 pm    Post subject: Doesn't work siemens tiuning fw 43 links Reply with quote
Please fix this link http://www.siemensmania.cz/download.php?file=/other/Firefox%20by%20BS_Neo.sdt This Is Fire Fox theme.Thank You!
CX65-ka
PostPosted: Sat Aug 13, 2005 3:29 pm    Post subject: Reply with quote
This link is OK . What is your problem ?
I have CX 65
havros
PostPosted: Sat Aug 13, 2005 3:38 pm    Post subject: Reply with quote
Proc ho hned fixovat? To snad neni warez ne???
CX65-ka
PostPosted: Sat Aug 13, 2005 3:39 pm    Post subject: Reply with quote
Jezisi on pisal ze mame opravit ten link lebo sa mu neda stiahnut ten tuning !!! Ale uz sa da stiahnut tak je to vyriesene .
I have CX 65
havros
PostPosted: Sat Aug 13, 2005 3:42 pm    Post subject: Reply with quote
OK, tak sorry, nejsem nejakej prebornik v anglictine, tak se hned nerozciluj...
kenas
PostPosted: Sat Aug 13, 2005 3:44 pm    Post subject: Reply with quote
Ne podle me mysli, ze mu naskoci to okno kde sou nesmyslny znaky, kde musi dat ulozit stranku jako.
Oki, click on this link : [url] http://www.siemensmania.cz/download.php?file=/other/Firefox%20by%20BS_Neo.sdt[/url] and click on File - Save page as (CTRL+S)
Warning: Parse error in /home/www/signature.php on line 144
wizaard
PostPosted: Sat Aug 13, 2005 3:51 pm    Post subject: Reply with quote
CZ pro ostatní: Pánové, víte vy vůbec, co je to za soubor? Je to TÉMA!!! Ne tuning. d'oh!
EN for Dowisss: Yeah, I guess there's some problem with the link or file, I don't know exactly. When I open the link, the websystem tells me that I'm not logged in even if I am. I don't know what's wrong... Confused
Hynal
PostPosted: Sat Aug 13, 2005 3:56 pm    Post subject: Re: Doesn't work siemens tiuning fw 43 links Reply with quote
Click on your link(right mouse button) and chose: Save target as.
CZ: Nevim co mate za problem, ale me to jde stahnout vpohode, tak jak sem psal.
wizaard
PostPosted: Sat Aug 13, 2005 4:01 pm    Post subject: Re: Doesn't work siemens tiuning fw 43 links Reply with quote
CZ: Zajimavé, mně to nejde... co máš za prohlížeč? Já mám Firefox 1.0.6...
I guess it's a broken link...
CX65-ka
PostPosted: Sat Aug 13, 2005 4:02 pm    Post subject: Reply with quote
Ano tie nesmyselne znaky naskocia vo firefoxe ale ked ides cez IE tka ti naskoci stahovanie a opyta sa kam to chces ulozit!!
I have CX 65
Hynal
PostPosted: Sat Aug 13, 2005 4:07 pm    Post subject: Re: Doesn't work siemens tiuning fw 43 links Reply with quote
Mam Operu 8 a facha to vklidu. Musis to ale pres ten link co poslal on, ne kenas. Kenas ma vtom linku chybu, konci mu adresa Neo.sdt[/url]
wizaard
PostPosted: Sat Aug 13, 2005 4:25 pm    Post subject: Re: Doesn't work siemens tiuning fw 43 links Reply with quote
No, toho, že tam má .::kenas::. chybu jsem si samozřejmě všiml... Jak jsem psal, když na ten link kliknu, napíše mi websystém, že nejsem přihlášenej, což není pravda.
