:: View topic - Kabel na prepojenie dvoch mobilov
Goto page 1, 2, 3, 4, 5, 6, 7  Next
Sh@dy
PostPosted: Sat Aug 13, 2005 10:55 pm    Post subject: Kabel na prepojenie dvoch mobilov Reply with quote
Co si o tom myslite? Bolo by to mozne? Vyuzitie by to naslo v java aplikaciach (nebol by problem aplikacia na posielnie suborov cez kabel - rychlejsie ako IrDA... alebo multiplayer hry)
Hynal
PostPosted: Sat Aug 13, 2005 11:08 pm    Post subject: Reply with quote
No ja myslim ze by to teoreticky slo. Kdyz vemu USB datak a pripojim ho jen k telefonu a ne do PC, tak se v telefonu taky identifikuje. Takze by to melo jet, otazkou je jak si budou telefony rozument.
Ale nechcu byt prvni kdo to vyzkousi Very Happy Snad by se nemelo nic stat(snad)
sidbin
7892.64 SMM
PostPosted: Sun Aug 14, 2005 12:26 am    Post subject: Reply with quote
no jo,ale on ho identifikuje pomoci propojenych pinu Shame on you Shame on you
-zkratka propojis urcite kontakty a telefon napise co to znamena
Uz jsem zradil, mam SE W810i
Užitečné java aplikace ZDE
Sh@dy
PostPosted: Sun Aug 14, 2005 9:32 am    Post subject: Reply with quote
Malo by to ist priamim prepojenim pinov (len 2 konektory a kabel) a komunikovalo by to len v java aplikaciach. Robim teraz jednu aplikaciu co komunikuje so seriovym portom a podarilo sa mi aj spojit mobil s emulatorom, tak si myslim, ze by malo ist prepojit aj mobil s mobilom. Keby som mal 2 konektory na siemens, tak by som to uz davno vyskusal. Ak by sa niekto rozhodol to vyskusat, tak by som mu spravil jednudochu aplikaciu na posielanie sprav cez serial port...
Hynal
PostPosted: Sun Aug 14, 2005 3:08 pm    Post subject: Reply with quote
No asi treba takhle, ne?
EDIT: Spojte GND telefonu Smile
Sh@dy
PostPosted: Sun Aug 14, 2005 3:18 pm    Post subject: Reply with quote
http://img138.imageshack.us/img138/812/schema9yy.png
Asi tak by to malo byt... Najde sa niekto, kto to vyskusa? Kym sa ja dockam konektorov, tak by to mohol niekto vyskusat. Nemal by byt pre nikoho problem "zostrojit" nieco take.
Hynal
PostPosted: Sun Aug 14, 2005 3:28 pm    Post subject: Reply with quote
Konektor stoji tak 60-80 korun. To si myslim ze je kvuli testu s nezarucenym vysledkem docela dost.
Spis kdyby byli dva lidi s datovejma usb kablama a spojily je dohromady. To by bylo skozo zadarmo.
Sh@dy
PostPosted: Sun Aug 14, 2005 3:36 pm    Post subject: Reply with quote
Ale ved konektory nijak neposkodis... Takze ked ma niekto k dispozicii 2 konektory tak by to mohol vyskusat.
EDIT: mam doma 2x C65, 2x handsfree a rezistorov az vela, tak skusim ten kabel spravit... Druhu C65 ma sestra a teraz neni doma, tak sa potom ozvem, ked pride. Malo by to byt este dnes.
CX65-ka
PostPosted: Sun Aug 14, 2005 4:41 pm    Post subject: Reply with quote
No to som zvedavy ci sa vam to podari .
I have CX 65
Marek65
PostPosted: Sun Aug 14, 2005 4:50 pm    Post subject: Reply with quote
No tato myslienka napadla uz aj mna ale myslim si ze to nepojde,lebo ked prepajame nejake zariadenia cez USB tak jedno je Hostitel(vascinou PC) a druhe Host(mobil,tlaciaren,fotak,...),teda Hostitel ma inu hardwarovu konstrukciu ako Host. Cize sa nedaju len tak spojit dve zariadenia Host alebo Hostitel. No PC sa daju vlastne pomocou USB kabla prepojit ale ten kabel ma v strede svaby. Takze ja si myslim ze to nepojde. Jedine ze by ktosi vynasiel nejake zapojenie ako je to pri tych PC. Som zvedavy ci sa to komusi podari.
Motorola C332 -> Siemens CX65 FW50 + DCA-540 homemade + DCA-500 homemade + Lampička -> SE W710i + 512MB card
Hynal
PostPosted: Sun Aug 14, 2005 5:11 pm    Post subject: Reply with quote
To mas pravdu. Jenze telefon jde spojit s PC pres rozhrani RS232. Tudiz jdou data s telefonu na prevodnik, pres nej do PC. Nazpatek to jde taky pres prevodnik. Tudiz by si meli telefony rozumet aji bez prevodniku, protoze komunikuji ,,stejnym jazykem". S USB by to potom nemelo mit nic spolecnyho. Aplikace se napise jako pro komunikaci se seriovym portem a mohlo by to jet, ne?
Pod je ma teorie chybna opravte me Smile
Marek65
PostPosted: Sun Aug 14, 2005 5:16 pm    Post subject: Reply with quote
V podstate mas pravdu aj ty. Sak uvidime co z toho bude.
Sh@dy
PostPosted: Sun Aug 14, 2005 5:48 pm    Post subject: Reply with quote
Funguje to nejak tak, ako si to napisal...
Nema niekto 2 kable, hociake... Ide len o to, aby mobil rozoznal prislusenstvo (kabel) a potom hoci aj rovno na piny (3 a 4) pripojit nejake kable, druhe konce kablov pripojit na druhy mobil krizom (3. pin na 4. a naopak...) Ja by som poslal aplikaciu, ktora by zistila, ci je spojenie medzi mobilmy...
Sh@dy
PostPosted: Sun Aug 14, 2005 7:23 pm    Post subject: Reply with quote
Vidim, ze sa tu asi nenajde nikto kto ma dva kable... Tak uz som dohodol s kamaratom, ze mi zajtra pozicia jeho kabel a vyskusam to sam.
sidbin
7892.64 SMM
PostPosted: Sun Aug 14, 2005 8:20 pm    Post subject: Reply with quote
nema byt nahodou na tom kabelu jeste propojeni GND?
me vzdelani me rika ze bez GND to asi nepujde Shame on you
Page 1 of 7
