:: View topic - Mrtvej foun?
Mrtvej foun?
Goto page 1, 2, 3  Next
forseti
PostPosted: Sun Jul 24, 2005 1:46 pm    Post subject: Mrtvej foun? Reply with quote
Zdrawim, nemuzu nic nahrat na founa jako myslim eeprom,ff atd. prez v-klay,winswup,martech tool a prez freiu nejde zmenit imei. Kdyz zapojim telefon kratce zmacknu cerveny tlacitko vsechno bezi jako ze v pohode, ale martech tool mi pise ze port com3 je pouzivan nebo neni zapojen, winswup mi hazi presne tohle Error on waiting for Ack EOT. Nevite co s tim?? Jo pricina vcera sem nahral naky patche vsechno bezelo v pohode a dneska sem founa vypnul a kdyz sem ho zapinal tak proste vzdycky kixnul. thx
Edit.: V-klay mi pri nahravani FF napise "An unknown error occurred while accessing COM3. Loader not ready!"
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger
forseti
PostPosted: Sun Jul 24, 2005 8:25 pm    Post subject: Prosim help =) Reply with quote
Tohle mi pisou programy ktery sem zkousel:
M55 Tool
.. Writing Flash ... OK
............... Transmision Error .............
................... Ready .....................
WinSwup
Freia
TTY_OpenCOMPort : opening COM3
COMM_IsBootRunning : bootcode does not seem to be running
COMM_LoadBoots : Waiting to power on the phone ...
COMM_LoadBoots : phone is powered on
COMM_LoadBoots : internal loader version is 01.00
COMM_LoadBoots : EEPROM IMEI is **************
COMM_LoadBoots : original IMEI is ************** (locked)
COMM_LoadBoots : found SIEMENS M55i lg1 v91 (1)
COMM_LoadBoots : flash ids are ********* [*********] - ****
COMM_LoadBoots : phone ids are ********* [*********]
COMM_UpdateIMEIBlocks : update is not accepted
este sem zkousel Martech tool a SST .. martech se vubec nespojil, SST nekomentuju =)
To bude asi testpoint,co?
Johny007
PostPosted: Sun Jul 24, 2005 10:45 pm    Post subject: Reply with quote
Ty brdo co jsi nahraval za patch?
M55 Iridium - TestPoint , FW11 + mojepatche.txt HP iPAQ 514 WM6
Sirus
7910.50 SMM
PostPosted: Mon Jul 25, 2005 7:12 am    Post subject: Reply with quote
Jedine patch co zasahuje do Bootcore by mohol takto posahat fon.... Ale to sa mi nezda, take patche sa nerobia...
forseti
PostPosted: Mon Jul 25, 2005 10:06 am    Post subject: Reply with quote
Nahraval sem jenom patche z SM... Evil or Very Mad Ale hlavni je co s tim? =))
Guest15
Location: Frýdek-Místek (malé velkoměsto kousek od Ostravy :)
PostPosted: Mon Jul 25, 2005 10:13 am    Post subject: Reply with quote
zkus nahrat FF pomoci x65 flasher.....musis ale pro x65 falsher pouzit svuj loader....me to tak pomohlo
Motorola T2288 -> Siemens MT50 -> Siemens CT65 -> Siemens C65 -> Siemens S65 -> Siemens SX1 konečně
forseti
PostPosted: Mon Jul 25, 2005 1:10 pm    Post subject: Reply with quote
No hlavne ze zasirate forum postama, ktery mi nepomuzou!! Snad krome guest15...
PostPosted: Mon Jul 25, 2005 1:47 pm    Post subject: Reply with quote
Klidek...precital si si,co Ti radi Guest15?
A aky mas Ty telefon? Tak trochu rozmyslaj,co Ti kto radi........ Shame on you
Sirus
7910.50 SMM
PostPosted: Mon Jul 25, 2005 2:27 pm    Post subject: Reply with quote
Myslis, ze som sa pytal, len tak zo srandy, aky patch to bol? Myslel som ze je to nejaky nestandardny a v tom pripade by sme sa do neho mohli mrknut ci naozaj zapisoval do bootcore.
forseti
PostPosted: Mon Jul 25, 2005 3:11 pm    Post subject: Reply with quote
Jo (sem)vklidu, to nebylo mysleno vazne ... sorry
Mobil M55
Zkousel sem x65 Flasher se mi vubec nespoji, patch ja nevim daval sem jich tam fakt hafo... mrknu ktery sem daval jako posledni
Posledni patche co sem nahraval byli,vzestupne:
sound_on_off.vkp
font2.vkp
grad_cierne.vkp
font.vkp
m55v11_net-bat-nonia.zip
czcionka.rar
Ukazatele_by_Tolek.vkp
M55v11_cisla_na_hodiny_po_zamknuti_klaves.vkp
No nevim videl bych ze naky problemy tam mohl udelat systemovej patch no.371 M55i_v11.vkp. Mozna ze by na tom mohl mit podil i patch na postupne ztmavovani displeye, protoze ten telefon bezel prez noc uplne v pohode a druhy den kdyz sem ho vypnul a pak ho chtel zapnout tak se vypnul, resp. zapnul se ale pri nacitani ztmavoval displey az se telefon uplne vypnul zkousel to ho 3x zapnout a to samy...
PostPosted: Mon Jul 25, 2005 6:11 pm    Post subject: Reply with quote
Ked si tie patche aplikoval,nestalo sa Ti,zeby Ti V_Klay vypisal hlasku o nezhode dat alebo zapisovania do bootcore?
Johny007
PostPosted: Mon Jul 25, 2005 6:52 pm    Post subject: Reply with quote
Mobil M55
sound_on_off.vkp
font2.vkp
grad_cierne.vkp
font.vkp
czcionka.rar
Njn je to urcite to M55i to pracuje s bootcore.. to bych si tam ani nedaval.. a to mam testpoint
forseti
PostPosted: Mon Jul 25, 2005 7:11 pm    Post subject: Reply with quote
Myslim ze ne .. o neshode, jako ze mi pak Vklay vnutil vytvorit **_REPAIR.vkp to jo ...
forseti
PostPosted: Mon Jul 25, 2005 7:12 pm    Post subject: Reply with quote
Njn je to urcite to M55i to pracuje s bootcore.. to bych si tam ani nedaval.. a to mam testpoint[/quote]
No ja sem proste jel po tech patchi a ladoval to do slozky, ale pak mi prislo jako ze to neni fakt moc dobrej napad =) Tak sem daval zrusit patch ale uz to jak si neslo... nejspis =)
Takze tahle M55 ma konecnou?
forseti
PostPosted: Mon Jul 25, 2005 11:07 pm    Post subject: Reply with quote
Mi uz nehelpne co? Naky napady Pls Pray
Asi ne .. v tom pripade prodam super mobila M55 s FW91.. rozsirenej disk na 3,6MB s T9. Rok pouzivany,neopotrebeny,Iridium + USB kabel k tomu, bohuzel bez zaruky. Bohuzel mi odesla nabijecka a baterka je vybita takze nejde zapnout ale staci jenom "nabit" Whistle Angel Pri rychlem jednani bonus Siemens C25 nebo C35i =))
Koupim M55 nejlip Black Magic Exclamation Rolling Eyes
Page 1 of 3
