:: View topic - How to make own lang-pack?
Reply to topic     Forum Index -> Non Czech Languages Here
Siemensiak
PostPosted: Mon Oct 17, 2005 1:48 pm    Post subject: How to make own lang-pack? Reply with quote
I'm trying to increase memory in M55 v11. Everything is OK, but I don't know how to make fuc**ng language pack with polish language. I have tried using Smelter and Notepad, but all the time I see strange signs instead normal phrases in the menu.
Lang pack with Czech or Sloviak from this site is working, but I want to create my own. Please help me... How to do that? How to make lang pack?
I opened full flash (bin) with Smelter, clicked on Save whole langpack, edited the *.lgp file (erasing non polish languages), saved the modified *.lgp, clicked Load whole langpack and Save langpack-area. The file has 64 kb. But after writting it to the phone, there are strange signs instead for example polish: "Enter Pin". What am I doing wrong?
Please help me! Crying or Very sad
PostPosted: Mon Oct 17, 2005 5:26 pm    Post subject: Reply with quote
1, After rstore lgp try code *#0000#.
2, Or try to save only polish lgp from FF. After right mouse click there will be a offer to show only a polish language.
Siemensiak
PostPosted: Mon Oct 17, 2005 11:11 pm    Post subject: Reply with quote
It's not possible to save only polish with Smelter.
I tried your suggestions, but all the time there are strange signs. Moreover - if I edit some good lang-pack (using Smelter and UltraEdit) the situation is the same - strange signs. Please help me ;(
Maybe the Smelter is wrong? Which version do you use?
Regards from Poland!
Siemensiak
PostPosted: Tue Oct 18, 2005 12:47 am    Post subject: Reply with quote
OK, it works now when I enter *#0001# / green.
But your lang pack works every time!
Using my when I enter *#0048# (for polish) or *#0000# strange signs backs.
Please help me last time!
Siemensiak
PostPosted: Tue Oct 18, 2005 1:07 am    Post subject: Reply with quote
I think, I have to do that using Siemens Language Editor and set there parameters for M55. But how?
For M55 v10 it's:
PhoneType M55_10, BA0000, 40000,6,8,a,c,e,10,12,16,2a,3c,0,0
But for M55 v11?
Or any another idea?
Little_S
PostPosted: Wed Oct 19, 2005 6:48 pm    Post subject: Reply with quote
you're on right way.
edit the header like this:
Code:
PhoneType M55_11, 000000, 10000,6,8,a,c,e,10,12,16,2a,3c,43,0
AllLangs x
MaxMsgId 3836
LgPackId lg1
; Language data
LangId 1
phone type, not sure if the 11 is right, but it'd work, the zeros is adress, you need to type it at loading in phone (in vklay) and then's the size, if you want one language then 10000 is far enough
AllLangs - number of languages in LGP, for polish only 1 and so on...
MaxMsgId - id of the last message in LGP, or just number of messages in LGP
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
Reply to topic     Forum Index -> Non Czech Languages Here All times are GMT + 1 Hour
