:: Zobrazit téma - If firmware update with USB DCA-510 cable does not work?
Odpovědět na téma    Obsah fóra -> Non Czech Languages Here
Vladimir Curcic
Založen: 30. 04. 2005
PříspěvekZaslal: pá prosinec 16, 2005 7:41 pm    Předmět: If firmware update with USB DCA-510 cable does not work? Odpovědět s citátem
This is from the original FAQ on Siemens site, for those of you who experienced described problem with DCA-510:
Solution
If any Bluetooth™ serial stuff is installed on your computer, update tool hangs during scanning BT-COM-Ports.
The mapped COM-port-number is greater than 10. Example: Update works fine if mapped to COM7.
Update does not work if mapped to COM24.
Hint: you cannot influence the mapped COM-portnumber, it is set by system during installing!
To solve problem:
Rightclick on workstation symbol on desktop -> properties -> Hardware -> Device Manager.
Click on the List at "Ports (COM & LPT)" and rightclick on BT-Port to deactivate it; also make a rightcklick to check -> properties -> settings -> advanced -> select a free COM-Port number less than 10.
I hope this will help somebody
Razz
S65(FW58) | IFL-600 (External flash) | DCA500
MY CURRENT COLLECTION: ME45 | S45i | CX65-LtdEd | S65 | SL75
Založen: 25. 11. 2004
PříspěvekZaslal: so prosinec 17, 2005 8:55 am    Předmět: Odpovědět s citátem
Great that you shared it with us but we know this since 3/2004. Smile
Vladimir Curcic
PříspěvekZaslal: so prosinec 17, 2005 11:51 am    Předmět: Odpovědět s citátem
Lasky napsal:
This was ment for people who don't speak Czech and I thought it would help them, besides I have not seen anything on the subject on the Non Czech Languages part of the forum...
Odpovědět na téma    Obsah fóra -> Non Czech Languages Here Časy uváděny v GMT + 1 hodina
