5874.50 SMM
Zaslal: čt prosinec 22, 2005 7:30 pm Předmět: palette.dll na c/e |
takze FCA00000 na servry SMO sa vyjadril ze 4.1.2006 releasne program ktory umozny presmerovanie palette.dll na c/e..takz nebude potrebny zadny flash na zmenu palety:)
citace: | OK, the good news it that I have it working.
The bad news is that it is a bit difficult to load it. Not only you need to put it on C: , but also needs an extra program.
I will release around 2006.01.04 because I will be busy with other topics for some time. |
Gwin čestný člen
0.84 SMM
Zaslal: čt prosinec 22, 2005 10:40 pm Předmět: |
Snad to nebude jako s kisswupem  _________________ Alcatel 301 => Alcatel 301 => Nokia 3210 => Nokia 3310 => Nokia 3410 => Siemens SX1 => Nokia E51-1 => HTC TyTN II => Samsung GT-I8190
