:: View topic - Unlock C60
Unlock C60
Reply to topic     Forum Index -> Non Czech Languages Here
hungeri
PostPosted: Sun Dec 25, 2005 3:33 pm    Post subject: Unlock C60 Reply with quote
Hi guys!
I've got a problem with unlocking a C60. Freia can't boot, nor V_klay and SST... It has got SW 25, before this it was in service center, and they told, something was modified in the hardware. They didn't tell, what... I had got an M55, and I remember, there was a JAVA Midlet to patch the bootcore, after this worked anything cool, but unfortunately I can't find this midlet (as I donno its name), so maybe this is also required for C60, too? I have DCA-510.
Thanx Guys!
To Lasky:
Olvastam az új JAVA-s patchről, ami a Te cikked a főoldalon, persze egy kukkot sem értettem belőle, de a képek nagyon érdekesek! Letöltve a patch-et, láttam, hogy M65_fw58 még nincs benne. Várható hogy lesz? Mert igen érdekes ez a megoldás.
Amúgy Boldog Karácsonyt és Újévet ! :)
PostPosted: Sun Dec 25, 2005 4:16 pm    Post subject: Reply with quote
Patch bootcore with this midlet. But works only to FW23 and lower. Than you can updete it.
Arrow http://www.mobilmania.cz/hosting/siemensmania/utility/px5amd.zip
-magyarúl:
Ez csak komplikáttan néz ki. Amúgy olyan egyszerú mind a normális patcholás. Egyszerúen kell iket aplikálni. Csak hogy most nem a *.vkp-ben kell álitani hanem a javában.
M65v58-re még nincs meg és még nem is láttam semmit róla. Egy picit szkeptikus vagyok ebben. De lehet hogy egyszer meglesz.
hungeri
PostPosted: Sun Dec 25, 2005 5:37 pm    Post subject: Reply with quote
So, Freia prompted me "COMM_UpdateIMEIBlocks : update is not accepted"...
have downgrade to fw23, run px5amd, but freia isn't work. Can I try with SST? I've made a C55 wrong, I don't want to make it with C60 too, as I haven't got another C60 (C55 I've had)...
Reply to topic     Forum Index -> Non Czech Languages Here All times are GMT + 1 Hour
