5874.50 SMM
Posted: Tue Jan 10, 2006 7:10 pm Post subject: sx1 a MMC overclocking patch |
davajte pozor najprv si ho prestudujte:)
Patch No. 51
; SX1 overclock patch v1.0
; v1.0
; changes bootcore of Z1 firmware image
; by Vovan888 (vovan@oslik.ru) 08.01.2006
; oslik.ru
; dedicated to Z-team and overclockers.ru
; !!! DANGER !!! CPU can overheat and overburn !
;168 Mghz
replace:303A00000010FEFF00102000FFFFFEFFEFFFFFD1:303E
; multipliers table: (cpu_freq = 12 * mult / 2)
; mult
;11 10100 01 10000
;01101 = 13 = 78M = 11011010110000=36B0
;10100 = 20 = 120M = 11101000110000=3A30
;11001 = 25 = 150M = 11110010110000=3CB0
;11100 = 28 = 168M = 11111000110000=3E30
;11101 = 29 = 174M = 11111010110000=3EB0
Patch No. 52
; Increase MMC Speed (test) v0.1
; Sets MMC freq to 24 Mghz
; by Vovan888 ( vovan(at)oslik.ru ) 08.01.2006
; Ekern_exe_421
;50005E08
replace:030052E30900000A020000CA000052E3:02
;50005E40
replace:0320A0E3DC8E00EA0C68005808009FE5:02
; epbusm.dll
;5002F11C - change ADDNE R3, R4, #1
replace:013084120338A0112348A0110C00A0E3FF10A0E3:013044020338A0012348A001
fROM
http://forum.oslik.ru/viewtopic.php?t=7933&start=45
Code: |
results in SPMark04_v110_free_S60
120mghz
score=492
8.28 fps
1.93Mtexels/s
24.27 Ktriangles/s
150mghz
score=615
10.38 fps
2.40Mtexels/s
30.41 Ktriangles/s
168mghz
score=695
11.68 fps
2.73Mtexels/s
34.16 Ktriangles/s |
KŘOVÁK rozumbrada
 Joined: 01 Jun 2005 Posts: 385 Location: V křoví-Afrika
Posted: Tue Jan 10, 2006 7:38 pm Post subject: |
mohl by si prosim te trosku vysvetlit k cemu ze to je?  _________________ "I myšlení občas škodí zdraví."
(\__/)
(O.o )
(> < ) THIS IS BUNNY!
5874.50 SMM
Posted: Tue Jan 10, 2006 7:45 pm Post subject: |
prvy patch pretaktuje procesor na 168 MHZ a druhy citacku MMC na 24 MHZ |
Norton rozumbrada
1272.54 SMM
Posted: Tue Jan 10, 2006 8:36 pm Post subject: |
Už jsem na to koukal na SFku a jak budu mít chvilku čas,tak to zkusím.Někdy opravdu žasnu co všechno s těma našima "miláčkama" jde udělat. Za tohle prostě Siemensy miluju. _________________ C35i -> MT50 -> CX65 -> SX1 -> Nokia N70 |
jaramara věrný diskusník
Posted: Tue Jan 10, 2006 9:34 pm Post subject: |
Jede to a jde to hodně poznat na rychlosti, fakt super! Ale když jsem do svýho packu přidal i ten na MMC, tak se žádný OC nekonalo, ale pak to ještě zkusím předělat! _________________ Siemens SX15en(czT9)/ja_ma mod 36patches core 168Mhz !!DEATH!! =); Trancend512MB; joy 6600 and Samsung X200 (vodafone)
NOW_NOKIA_ /\/70 _ rulezz =) |
5874.50 SMM
Posted: Tue Jan 10, 2006 9:37 pm Post subject: |
ako myslis kartu to nepretaktovalo? |
Posted: Tue Jan 10, 2006 9:39 pm Post subject: |
duuri wrote: | ako myslis kartu to nepretaktovalo? |
No to nevím a ani nevím jak bych to mohl pozorovat, ptž když jsem tam přidal obadva, tak se žádný OC nekonalo, tak jsem ten patch na MMC vyhodil a v pohodě, ale zkusím to ještě nějak upravit, celý ten pack.
Ty jsi to už zkoušel? _________________ Siemens SX15en(czT9)/ja_ma mod 36patches core 168Mhz !!DEATH!! =); Trancend512MB; joy 6600 and Samsung X200 (vodafone)
5874.50 SMM
Posted: Tue Jan 10, 2006 9:46 pm Post subject: |
dal som tam obidva ale ja som podtaktoval na 78 a menu ide pomalsie...takze u mna to snad ide len ako testnut kartu snad nejakym softom na test kariet pod symbianom |
Posted: Tue Jan 10, 2006 9:49 pm Post subject: |
duuri wrote: | dal som tam obidva ale ja som podtaktoval na 78 a menu ide pomalsie...takze u mna to snad ide len ako testnut kartu snad nejakym softom na test kariet pod symbianom |
Jn, takový žádný neznám Ale nějak jsem vůbec nepochopil k čemu to může být dobrý
Nemůže se tím MMC poškodit? _________________ Siemens SX15en(czT9)/ja_ma mod 36patches core 168Mhz !!DEATH!! =); Trancend512MB; joy 6600 and Samsung X200 (vodafone)
5874.50 SMM
Posted: Tue Jan 10, 2006 9:50 pm Post subject: |
ono povedne to bolo od siemensu ale potom to znizili v novsom firmware kvoly kompatibilite...ale malo by byt rychlejsie citanie a zapisovanie na kartu |
Posted: Tue Jan 10, 2006 9:57 pm Post subject: |
duuri wrote: | ono povedne to bolo od siemensu ale potom to znizili v novsom firmware kvoly kompatibilite...ale malo by byt rychlejsie citanie a zapisovanie na kartu |
Tzn. že by se i mohl zrychlit třeba MsVDriveE? _________________ Siemens SX15en(czT9)/ja_ma mod 36patches core 168Mhz !!DEATH!! =); Trancend512MB; joy 6600 and Samsung X200 (vodafone)
5874.50 SMM
Posted: Tue Jan 10, 2006 10:25 pm Post subject: |
no teoreticky hej ale ved msvdrive pustis len raz...skor by som povedal ukladanie videa alebo tak |
paja_m55 badatel
Posted: Wed Jan 11, 2006 8:14 am Post subject: |
jaramara wrote: | duuri wrote: | ono povedne to bolo od siemensu ale potom to znizili v novsom firmware kvoly kompatibilite...ale malo by byt rychlejsie citanie a zapisovanie na kartu |
Tzn. že by se i mohl zrychlit třeba MsVDriveE? |
msdrivee ti jenom presmeruje ukladani na kartu takze ten zapis sms/mms by mel byt pak rychlejsi,no vyzkousim,snad phone neusmazim jako cpu v pocitaci a jeste jedna vec? jakej to ma vliv na baterku? vydrz musi jit rapidne dolu,co?  _________________ 2x C35i -> OT501 -> SGH-C100 -> M55 -> SX1 -> S65 -> Nokia E50 -> Nokia E51 -> T-Mobile MDA Compact IV
--== AMD 4evr ==-- |
Gwin čestný člen
0.84 SMM
Posted: Wed Jan 11, 2006 11:22 am Post subject: |
Pokud ty patche funguji, bude to parada. Co nejdriv vyzkousim. _________________ Alcatel 301 => Alcatel 301 => Nokia 3210 => Nokia 3310 => Nokia 3410 => Siemens SX1 => Nokia E51-1 => HTC TyTN II => Samsung GT-I8190
Posted: Wed Jan 11, 2006 1:06 pm Post subject: |
Takže od rána pořád něco dělám, mám OC na 144MHz a úplně v pohodě , myslím že to moc víč žrát nebude  _________________ Siemens SX15en(czT9)/ja_ma mod 36patches core 168Mhz !!DEATH!! =); Trancend512MB; joy 6600 and Samsung X200 (vodafone)
