palucko I <3 emo
Příspěvky na SM: 1016,- |
Zaslal: st prosinec 17, 2008 4:02 pm Předmět: COM kabel |
zdravim ,. prosim o radu kto ma skusenosti s COM kablom (žiadne USB)
je to neoriginalny s vypredaju urceny na x55
ked ho pripojim na zapnutu CX75 a stlacim nieco v papue mobil pixne
servisny rezim nejde ., napise awaiting power on phone a nasledne po cakani No answer no ping
ked stlacim tlacitko informacie podari sa mi toto ,.,. a IMEI to napise tak ako vidite
kód: | Auto Ignition...
Transfer boot...
Boot in "Service mode" Ok
Awaiting Power On phone...
No answer on Ping
Boot in "Service mode"...
Press RED key (Power ON)!
Auto Ignition...
Transfer boot...
No answer on Ping
No answer from the phone
Check port number, cable, phone, mode!
Getting Information:
Model: SIEMENS CX75 25 lg4
Phone is in "Format FFS?". SecurityStatus: "CustomerMode"
IMEI: 000000000000000
HWID: 5000
Attention: Charge Accumulator!
Accumulator Voltage: 3675 mV.
Code(05): OTP is Closed for write
Code(09): BootKEY is stored in EEPROM
Code(0C): Keys is not present in BCORE (cleared)
Code(10): BFC functions are inaccessible
Code(15): Full mode (not SC)
Code(1A): Block 76 is accessible
Code(1D): 512x blocks presents
EELITE Info: free buffer 119548 bytes, free at all 119576 bytes, free for deleted 119576 bytes.
EEFULL Info: free buffer 116134 bytes, free at all 204053 bytes, free for deleted 73013 bytes.
MAP info: Date: 11/11/11, Variant: A 407, Std-Map/SW: 1/13, D-Map/Prov.: 1/143
To Get Extended Info - Enter Skey into the phone!
Phone operated: 66709314 sec.. Total Talk time: 814218 sec.
FlashID(1) - Manufact. code:0089 (Intel), type: 880D. DisplayID(1,50): Philips Philips PCf8882. |
po rozobrani konektoru do mobilu som tam našiel zapojeny 2-3-4 pin
poradite mi ci upravou ide urobit stoho servisny ? _________________ Už mám len môj prvý siemens MC60 , všetky ostatné padli za obeť na 8. Sraze Siemensmanie , teraz robia radosť niekomu inému Nokia E51 - nabíjanie cez miniUSB
