:: Zobrazit téma - DCA 540 USB to service
Odpovědět na téma    Obsah fóra -> Non Czech Languages Here
gedeon77
Založen: 04. 02. 2006
PříspěvekZaslal: ne únor 05, 2006 9:22 pm    Předmět: DCA 540 USB to service Odpovědět s citátem
Is there any possibility to change dca540 usb into service cable
Poland greetz:)
furcian
Založen: 21. 05. 2005
PříspěvekZaslal: ne únor 05, 2006 9:23 pm    Předmět: Odpovědět s citátem
eee Sad
sew200i
sl55
s55
beardie
Založen: 19. 01. 2005
7865.50 SMM
PříspěvekZaslal: ne únor 05, 2006 9:24 pm    Předmět: Odpovědět s citátem
no, dca540 is only a data cable, it doesn't involve electronic parts as dca510
gedeon77
PříspěvekZaslal: ne únor 05, 2006 9:26 pm    Předmět: Odpovědět s citátem
but my dca540usb have electronics part in usb plug. whats the difference. i thought that only in voltage (data cable doesnt have)
Poland greetz:)
Mar3x
Založen: 30. 07. 2005
PříspěvekZaslal: ne únor 05, 2006 9:39 pm    Předmět: Odpovědět s citátem
It is possible, but you need Prolific PL2303 USB<->UART converter.
I hadn't find any shop that is selling this chip, but maybe you can find some.
If you have it, you nearly did it. :-)
Then you just have to search the net for scheme of dca510 ...
I was looking for it because I needed that converter from it and it is possible to find that scheme. Then there are just a few external IC's ... some max232 (uart<->rs232) and optionally eeprom (if you have more of those cables, you can program unique ID there, so they wont have conflicts).
IMO instead of that prolific chip you can try to use FTDI FT232BM (that newer version).
It has nearly the same parameters and you can easily order it somewhere ...
(I have been playing with those FTDI chips these days ... they work great! :-) )
C25->MT50 FW18->S65 FW58-> >>>SXG75 FW22 + 1GB SanDisc<<< (a dalsi co mam v rodine M35i, ME45@S45i, CF62, CX65@CX70)
Debian GNU/Linux 3.1r1 + dalsi repozitare (KDE3.5.0; Linux 2.6.16-rc2-mm1)
gedeon77
PříspěvekZaslal: ne únor 05, 2006 9:44 pm    Předmět: Odpovědět s citátem
so...its easier to buy a service cable lol tnx for info
mar3x...interesting tnx
without service mode patching isnt possible or maybe modification of swup is possible...
Poland greetz:)
Založen: 25. 11. 2004
PříspěvekZaslal: pá únor 10, 2006 11:11 am    Předmět: Odpovědět s citátem
gedeon77 napsal:
For patching you don´t need service mode.
gedeon77 napsal:
It is possible to modify patched fullflash into a userswup.
gedeon77
PříspěvekZaslal: pá únor 10, 2006 11:58 pm    Předmět: Odpovědět s citátem
and what next with userswup?
with datacable i can't write it....
Poland greetz:)
Odpovědět na téma    Obsah fóra -> Non Czech Languages Here Časy uváděny v GMT + 1 hodina
