gedeon77 kolemjdoucí
Posted: Sun Feb 05, 2006 9:22 pm Post subject: DCA 540 USB to service |
Is there any possibility to change dca540 usb into service cable _________________ Poland greetz:) |
furcian pisatel
Posted: Sun Feb 05, 2006 9:23 pm Post subject: |
eee  _________________ sew200i
sl55
s55 |
beardie táta fóra
7865.50 SMM
Posted: Sun Feb 05, 2006 9:24 pm Post subject: |
no, dca540 is only a data cable, it doesn't involve electronic parts as dca510 |
Posted: Sun Feb 05, 2006 9:26 pm Post subject: |
but my dca540usb have electronics part in usb plug. whats the difference. i thought that only in voltage (data cable doesnt have) _________________ Poland greetz:) |
Mar3x badatel
Posted: Sun Feb 05, 2006 9:39 pm Post subject: |
It is possible, but you need Prolific PL2303 USB<->UART converter.
I hadn't find any shop that is selling this chip, but maybe you can find some.
If you have it, you nearly did it. :-)
Then you just have to search the net for scheme of dca510 ...
I was looking for it because I needed that converter from it and it is possible to find that scheme. Then there are just a few external IC's ... some max232 (uart<->rs232) and optionally eeprom (if you have more of those cables, you can program unique ID there, so they wont have conflicts).
IMO instead of that prolific chip you can try to use FTDI FT232BM (that newer version).
It has nearly the same parameters and you can easily order it somewhere ...
(I have been playing with those FTDI chips these days ... they work great! :-) ) _________________ C25->MT50 FW18->S65 FW58-> >>>SXG75 FW22 + 1GB SanDisc<<< (a dalsi co mam v rodine M35i, ME45@S45i, CF62, CX65@CX70)
Debian GNU/Linux 3.1r1 + dalsi repozitare (KDE3.5.0; Linux 2.6.16-rc2-mm1) |
Posted: Sun Feb 05, 2006 9:44 pm Post subject: |
so...its easier to buy a service cable lol tnx for info
mar3x...interesting tnx
without service mode patching isnt possible or maybe modification of swup is possible... _________________ Poland greetz:) |
lacibogi čestný člen
Posted: Fri Feb 10, 2006 11:11 am Post subject: |
gedeon77 wrote: | without service mode patching isnt possible |
For patching you don´t need service mode.
gedeon77 wrote: | maybe modification of swup is possible... |
It is possible to modify patched fullflash into a userswup. _________________ C(ME)75
Lasky |
Posted: Fri Feb 10, 2006 11:58 pm Post subject: |
and what next with userswup?
with datacable i can't write it.... _________________ Poland greetz:) |
