:: View topic - Music player na pozadi ?
mobilcar
PostPosted: Sat Feb 25, 2006 7:24 pm    Post subject: Music player na pozadi ? Reply with quote
Zdarek cetl jsem uz od jednoho typka odtud z fora, ze mu jde music player na pozadi ma CX75 ku, je na to nejaky patch ? ja ho zatim neobjevil dikes Smile
CX75 v13 + xx patchu + DCA510 + Kingmax 245mb + 1550 java her
PostPosted: Sat Feb 25, 2006 7:33 pm    Post subject: Reply with quote
Je nato patch skok do menu po stlaceni ###
stefan.indian
PostPosted: Sat Feb 25, 2006 7:50 pm    Post subject: Reply with quote
ale to je native menu ne?
ja ked normalne pocuvam mp3, stlacim ### tak nic sa nestane, ak stlacim Pravy softkey (Menu prehravaca Mp3) az vtedy ak stlacim ### tak sa mi zapne native menu...
perco to nemoze byt tak zeaby mi v pozadi hrala mp3 a nieco ine robil?
jenda^^
PostPosted: Sat Feb 25, 2006 7:53 pm    Post subject: Reply with quote
Tak ten křížek nejdřív podrž, aby se zamknula klávesnice a až potom 3x # wink
Teď mám: Nexus S
mobilcar
PostPosted: Sat Feb 25, 2006 8:06 pm    Post subject: Reply with quote
a kdyz to pujde na to pozadi, pak muzu uz delat jinou praci s founem ? diky
beardie
7865.50 SMM
PostPosted: Sat Feb 25, 2006 8:09 pm    Post subject: Reply with quote
mozes posielat sms,hrabat sa v kalendari,... ale nesmies spustit inu javu alebo niekomu zavolat (prijimat hovory mozes)
petervranek
PostPosted: Sat Feb 25, 2006 10:57 pm    Post subject: problemy Reply with quote
ja som to vo FW 13 pouzival, ako pisete, ale ked som pisal sms, potom po navrate do MP3 a vypnuti prehravaca mi zamrzol mobil.
teraz som si vsak dal FW23 a moja CX75 je podstatne rychlejsia, avsak este nemam patch na ### - neviete o inych strankach kde to mozem najst ?
dik
Siemens CX75 FW23 + 512Mb + HFS 700 + DCA510
beardie
7865.50 SMM
PostPosted: Sat Feb 25, 2006 11:46 pm    Post subject: Re: problemy Reply with quote
zatial nie je, hned ako bude, tak bude aj tu wink
Už se naučte necitovat příspěvky nad sebou...; jenda.69
stefan.indian
PostPosted: Sun Feb 26, 2006 10:06 am    Post subject: Reply with quote
dik, uz to ide...
no ja normalne mozem hrat aj javove hry ak hraje mp3 Think len pri vypinani mi zamrzne...
dweller
PostPosted: Sat Mar 04, 2006 12:06 am    Post subject: Reply with quote
Este stale nie je patch na skok do native menu pre fw23?
the chosen one
