:: View topic - BCORE
BCORE
Reply to topic     Forum Index -> Siemens
pepo
74.30 SMM
PostPosted: Sat Mar 04, 2006 6:33 pm    Post subject: BCORE Reply with quote
Len ma zaujmalo niekolko veci-
Arrow BCORE je nieco ako bios na PC, a ked sa prepise zlymi hodnotamy tak sa moze telefon nadobro odpalit procesor v telefone ako v procesor v PC?
Question Question Question
A len tak pre zaujmavost cisto teoreticky nedal by sa procesor v napr. S65 vytaktovat z 104 na viac, aj keby to rapidne zahrievalo a zrala by sa baterka Question
Sak rusaci robia zazraky Very Happy
beardie
7865.50 SMM
PostPosted: Sat Mar 04, 2006 7:52 pm    Post subject: Reply with quote
bootcore je v podstate nieco ako bios
procesor nema zmysel pretaktovavat, je typu RISC=ohranicene pouzitie
a keby si ho aj pretaktoval, v com by ti to pomohlo?
pepo
74.30 SMM
PostPosted: Sat Mar 04, 2006 8:09 pm    Post subject: hardware Reply with quote
Mohol by byt ten telefon rychlejsi ne? ale nemas nejke odkazy na nejake zaujmave ruske stranky [anj, nem preklad abo obr] o hardware siemens-ov?
mohlo by to byt zaujmave Think
Bonfire
Phone: HTC HD2
9259.32 SMM
PostPosted: Sat Mar 04, 2006 10:44 pm    Post subject: Reply with quote
www.allsiemens.com tam se muzes porozhlidnout Smile pretaktovat muzes, ale nevim o kolik bys to chtel taktnout, aby to bylo poznat na chovani telefonu by se to melo pretaktovat o vic jak 50% (kdyz sem to podtaktoval na 52MHz tak to bylo defakto stejne, akorat java mirne pomalejsi)
Koupím Siemens, který nemám.
pepo
74.30 SMM
PostPosted: Sat Mar 04, 2006 11:21 pm    Post subject: Reply with quote
Hej v servisnom menu je "No 52MHz support" ale to v podstate konecnu frekvenciu nemeni je stale 104 len ked nie je alebo je zaskrtnute tak v pohotovostnom stave ma frekvenciu 26 alebo 52MHz. Neviem ktore je ktore ale ked si dam CPU clock dolava hore tak to tam vidim no sak pozrem ten link 8)
Bonfire
Phone: HTC HD2
9259.32 SMM
PostPosted: Sun Mar 05, 2006 12:14 pm    Post subject: Reply with quote
napis No 52MHz Support je asi jeste z x55, kde se tim podtaktovalo na 26MHz (zablokovalo se 52), ted se tim zabokuje 104 a jede to na 52/26MHz.
v overlay config ti bude preskakovat 104 a 26MHz, nevim proc se tam nezobrazi 52, ale kdyz zkusis jbenchmark tak vykon bude zhuba polovicni oproti normalnimu stavu
whitewash
0.00 SMM
PostPosted: Sun Mar 05, 2006 1:41 pm    Post subject: Reply with quote
Ešte k tomu BCORE - keď ho prepíšeš zlými údajmi, neodpáli sa ti nič, nakoľko BCORE nedokáže "ovládať" HW. Jednoducho ale nebude mať čo naštartovať Firmware, takisto telefón nebude reagovať na pokusy o externú komunikáciu (káble). Potom je jediná možnosť testpoint. Preto by som to neprirovnával k BIOSu, ale skôr k Bootloaderu, ktorý je zapísaný v MBR na pevnom disku.
EidzEm
VIP
VIP
5862.50 SMM
PostPosted: Sun Mar 05, 2006 3:00 pm    Post subject: Reply with quote
TO znamena, ze by sa napr. neslo spojit s v_klayom a tym by nesiel nahrat FF? Pochopil som to spravne?
PostPosted: Sun Mar 05, 2006 4:44 pm    Post subject: Reply with quote
Áno pochopil, odpoveď po stlačení červeného tlačidla prichádza práve z BC.
EidzEm
VIP
VIP
5862.50 SMM
PostPosted: Sun Mar 05, 2006 4:50 pm    Post subject: Reply with quote
Raz som zapisal do BCORE, lebo som toto nevedel. Este, ze sa nic nestalo. Teraz uz viem, preco sa neodporuca pri nahravani FF zapisovat do BCORE.
A ked nemusim stlacat cetrene tlacitko? Na pin 1 mam privedenych cca 5 V a tak ked aplikujem patche tak to tlacitko nemusim stlacat. Dalo by sa to obist tymto sposobom?
whitewash
0.00 SMM
PostPosted: Sun Mar 05, 2006 6:01 pm    Post subject: Reply with quote
no možno aj áno, ja keď dám vo VKlay možnosť TestPoint + pause 1.3s, tak sa mi tiež spojí s telefónom. Akurát si nepamätám, či vtedy musím stláčať tlačidlo alebo nie.
pepo
74.30 SMM
PostPosted: Mon Mar 06, 2006 7:10 pm    Post subject: Reply with quote
Tak co potom ovlada HW? Aka cast FF [ak je vo FF] je BIOS v telefone?
Reply to topic     Forum Index -> Siemens All times are GMT + 1 Hour
