:: View topic - Problem so zvetsenim flex memory na C60
darkrider89
PostPosted: Fri Mar 03, 2006 9:03 pm    Post subject: Problem so zvetsenim flex memory na C60 Reply with quote
postupoval som podla navodu na SM.Dal som si SK language pack a potom som dal na to ten patch.Ale ked zapnem mobil tak vsade vidim len znaky X.A pamat mam normalne zvetsenu na 3.75 Mb.Ked davam zapisat do telefonu SK language pack tak v polozke z adresy nemam na vyber ziadne 0x400000 (LangPack), tak som tam dal 0x00000000 (fullflash).Moze byt problem v tom?
Mar3x
PostPosted: Fri Mar 03, 2006 10:42 pm    Post subject: Reply with quote
no to teda urcite ...
normalne otevri ten soubor ve vklayi (open memory) a write memory .. adresy se nastavi samy
C25->MT50 FW18->S65 FW58-> >>>SXG75 FW22 + 1GB SanDisc<<< (a dalsi co mam v rodine M35i, ME45@S45i, CF62, CX65@CX70)
Debian GNU/Linux 3.1r1 + dalsi repozitare (KDE3.5.0; Linux 2.6.16-rc2-mm1)
darkrider89
PostPosted: Sat Mar 04, 2006 10:30 am    Post subject: Reply with quote
no ved ja ked otvorim ten subor tak sa mi tam uz samo nastavy ta adresa ja tam nemenim nic ani velkost
Mar3x
PostPosted: Sun Mar 05, 2006 10:15 am    Post subject: Reply with quote
no a to nejde, jo? btw. zkousel jsi prepnout jakyk v tlf?
darkrider89
PostPosted: Sun Mar 05, 2006 10:38 am    Post subject: Reply with quote
Uz mi to ide.Tu adresu som tam prepisal rucne
kansiz
PostPosted: Tue Mar 07, 2006 9:36 am    Post subject: Re: Problem so zvetsenim flex memory na C60 Reply with quote
