:: View topic - operator
operator
kelso
PostPosted: Sun Sep 19, 2004 5:03 pm    Post subject: operator Reply with quote
slo by ho nejako odstranit? len mi nepiste aby som si dal transparentnu farebnu schemu, lebo ked som tak urobil zmizol mi aj datum aj cas. takze ci sa da urobit nejaky patch - konkretne na C60
Grafic
PostPosted: Sun Sep 19, 2004 5:47 pm    Post subject: Reply with quote
Jako operatora si nastav pruhledny gif:)
kelso
PostPosted: Sun Sep 19, 2004 5:52 pm    Post subject: Reply with quote
a ked chcem tam mat obrazok na pozadi tak co mam urobit
Grafic
PostPosted: Sun Sep 19, 2004 6:05 pm    Post subject: Reply with quote
No, nevim jak na C60, ale ja mam na M55 moznost zvolit pozadi a operatora. Takze na pozadi si dam co chci a jako operatora nastavim ten pruhlednej gif.
kelso
PostPosted: Sun Sep 19, 2004 6:09 pm    Post subject: Reply with quote
hej hej jasne - nemal som zo sebou mobil ... ale uz viem. hej diky je to tak
kelso
PostPosted: Sun Sep 19, 2004 6:10 pm    Post subject: Reply with quote
mimochodom jak urobim ten priehladny gif?
KaRLiK_CZ
PostPosted: Sun Sep 19, 2004 6:31 pm    Post subject: Reply with quote
Nejjednodussi je napriklad nekoho pozadat, zda Ti ho neposle.
Sice jsi nepozadal, ale mas ho na mejlu.
Uz ani nevim v cem jsem to delal, ale myslim, ze v Adobe Photoshop 7.
1st : M55 TestPoint (dead - by water) -> CF62 (dead - by force) -> M65 ( live:)
2nd : A50 ( deathless:) -> M55 ( live:)
kelso
PostPosted: Sun Sep 19, 2004 6:41 pm    Post subject: Reply with quote
diky moc
Grafic
PostPosted: Sun Sep 19, 2004 7:06 pm    Post subject: Reply with quote
Ale da se to udelat i v malovani. Kreslit pruhledne.
kelso
PostPosted: Tue Sep 21, 2004 5:14 pm    Post subject: Reply with quote
diky ale ukazuje mi to ten znamy "kruzok, stcorcek, trojuholnik"
... a aj v mobile. co s tym?
moje_mc60
PostPosted: Sun Sep 26, 2004 6:34 pm    Post subject: Reply with quote
Poslal sem ti na mail ten co používám já na mc60. Posílal sem to známýmu myslim že zrovna na C60 a chodí to bez problémů. Zkus to. =P~
C25 -> C35 -> M35i (tuned grafic) -> SL45 (i) (patched) -> MC 60 (patched) -> M55 Iridium FW11 (patched) Smile
