:: View topic - Jak zlepšit kvalitu fotografií
Goto page 1, 2  Next
weitless
7981.00 SMM
PostPosted: Wed Aug 04, 2004 7:00 am    Post subject: Jak zlepšit kvalitu fotografií Reply with quote
http://www.siemensmania.cz/content.php?id=82
netron
PostPosted: Wed Aug 04, 2004 8:09 pm    Post subject: c60 Reply with quote
Chunguje to aj na c60? Ked vojdem do servisneho menu nemozem najst polozku Mini Monitor>Accessories.
Guest
PostPosted: Wed Aug 04, 2004 8:21 pm    Post subject: Reply with quote
Najprv chod v Dveloper menu do Configuration, zaskrkni Ext. Monitor a potom v Mini Monitore najdes Accessories.
Radek
PostPosted: Thu Aug 05, 2004 12:09 pm    Post subject: Reply with quote
Kde je to developer menu? Mám C60 a nevím kde to je.
Díky
PostPosted: Thu Aug 05, 2004 3:33 pm    Post subject: Reply with quote
Musis si ho aktivovat:
Arrow http://www.mobilmania.cz/hosting/siemensmania/dir_upravy/c60netmonitor.htm
huanacaraz
PostPosted: Tue Aug 10, 2004 11:55 am    Post subject: nefunguje pri S55 fw16 Reply with quote
v servisnom menu nemam polozku "acessoires" pod "mini monitor" ani v konfiguracii "HeapOvl config" sa neda vybrat 'ext monitor' - co stym?
(je to problem fw ?)
bol som trosku zbrkly, ked som to pisal, ale po navrate domov som zistil, ze som si odblokaval nie cele servisne menu, ale iba monitoring -> v tom bol problem Angel
tomekSK
PostPosted: Tue Aug 10, 2004 4:44 pm    Post subject: Reply with quote
A zaskrtol si si v Configuration Ext.Monitor,ako to tu uz niekto pisal?
Guest
PostPosted: Mon Aug 16, 2004 7:03 pm    Post subject: Reply with quote
nemozem sa dostat do servisneho menu-stale stlacam v menu # a nic
mam s55
Little_S
PostPosted: Mon Aug 16, 2004 8:26 pm    Post subject: Reply with quote
mam s55
servisne menu je treba najprv aktivovat a to cislom vygenrovanym z IMSI cisla telefonu alebo patchom
Hiper
Guest
PostPosted: Sun Aug 22, 2004 5:44 pm    Post subject: Reply with quote
Mam M55 a když zmačknu # tak se nic neděje nevim co s tim. Nemoh by na to vyjit nějaky Patch. Nejsem uplny začatečník a většina věcí od vás mi klape bez problému ale na tohle fakt nemůžu přijít. Dík
PostPosted: Mon Aug 23, 2004 10:09 am    Post subject: Reply with quote
Servisne menu si musis najprv aktivovat(navod na SM) a dostanes sa do neho stlacenim menu a #.
Strejda
PostPosted: Mon Sep 20, 2004 8:45 pm    Post subject: Reply with quote
To je hezky, ale nemuzu to tu najit. Muzes mi dat adresu,dik.
Guest
PostPosted: Tue Oct 12, 2004 11:39 am    Post subject: Reply with quote
Nemůžeš najít ??? ohhh vždyť to hanni psal o pár řádků výše ....
spatas
PostPosted: Mon Jan 16, 2006 12:34 am    Post subject: chodi to i na cf62? Reply with quote
tam jde jiz standartne nastavit zda lepsi ci horsi kvalita fotek.
tulen
44.72 SMM
PostPosted: Sat Jan 20, 2007 5:20 pm    Post subject: Reply with quote
ten link SM už nefunguje Sad
A65, CX75, EL 71
Goto page 1, 2  Next
Page 1 of 2
