:: View topic - Siemens A65 a spojeni pres USB
Reeboker
PostPosted: Fri Jun 23, 2006 12:37 pm    Post subject: Siemens A65 a spojeni pres USB Reply with quote
Tak co jak mam tento mobil spojit pres USB kabel???
Telefon:Siemens c72
Firmware:19
johnygrass
PostPosted: Fri Jun 23, 2006 12:38 pm    Post subject: Reply with quote
normal jakej máš typ kabelu??
C65>>S65>>S75>>SXG75
Reeboker
PostPosted: Fri Jun 23, 2006 12:43 pm    Post subject: Reply with quote
Nevim,jak to zjistim?
Telefon:Siemens c72
Firmware:19
johnygrass
PostPosted: Fri Jun 23, 2006 12:49 pm    Post subject: Reply with quote
na telefonu natukej *#06# potom dej více a zajed a ždolů tam je napsaný ACC a pot tím bude tvůj kabel nějak takhle DCA-atd.
Reeboker
PostPosted: Fri Jun 23, 2006 1:05 pm    Post subject: Reply with quote
Skousel jsem to na S c72 a tam je DCA-540
Telefon:Siemens c72
Firmware:19
johnygrass
PostPosted: Fri Jun 23, 2006 1:07 pm    Post subject: Reply with quote
a spojí se kabel s A65 píše něco kompl?
Reeboker
PostPosted: Fri Jun 23, 2006 1:10 pm    Post subject: Reply with quote
No prave ze ne ani nepipne
Telefon:Siemens c72
Firmware:19
johnygrass
jestli jo tak si stáhni Mobile phone Manager pro A65 a nainstaluj ho pak ti půjde kabel nainstalovat jako nějakej modem
132978.34 SMM
PostPosted: Fri Jun 23, 2006 1:17 pm    Post subject: Reply with quote
nevim, nevim... DCA-540 funguje jenom u x65 a výš , ale A65 je vlastně x55 Rolling Eyes Think
Reeboker
PostPosted: Fri Jun 23, 2006 1:20 pm    Post subject: Reply with quote
no nevim jestli to pujde Crying or Very sad
Telefon:Siemens c72
Firmware:19
johnygrass
PostPosted: Fri Jun 23, 2006 2:18 pm    Post subject: Reply with quote
tak co de to????
