:: View topic - DIY Slim lumberg
DIY Slim lumberg
Reply to topic     Forum Index -> Non Czech Languages Here
ahmedhosni2002
PostPosted: Mon Jul 03, 2006 2:20 pm    Post subject: DIY Slim lumberg Reply with quote
I've made about 7 x65 siemens accessories for now.
- Three 3.5mm audio converters
- Two USB DCA-540 data cables
- One Car charger
- One Aikon to Siemens charger adapter (u know Siemens phones & chargers are rare in Egypt)
One major obstacle when creating an accessory is the connector, I had to search for an old headset or data cable for just cutting its slim lumberg connector.
But I managed to create my own (Open source Very Happy) connectors from nothing.
So, I checked all cables & wires in my garage & found it Very Happy. It's a cable like ones inside:
1- CD-ROM drives (I had two dead ones)
2- CD players (an old Sony Hi-Fi)
3- Inkjet printers (a dead Epson)
it's the only suitable type because the distance between its wires is the same as it's between those in the phone connector
like this one
for one slim lumberg, you need about 4CM long, 14-wire wide of this cable in average.
I could get about 3 Meters of this cable
Phone connector needs 12 wires, but you'll cut a 14-wire wide piece of this cable (the extra 2 wires are not to be connected, but for best fit into phone)
Then it's easy to (expose) the 12 wires at both ends
Then find or make a (base) of plastic or rubber with diemensions fitting into the phone. Glue the cable over the plastic base.
That's all
My first DCA-540 (PC side directly connected to motherboard)
3.5mm converter under construction Wink
// Moved from Hardware; jenda.69
iko
PostPosted: Mon Jul 03, 2006 2:40 pm    Post subject: Reply with quote
Hi man, I don't think that here in Central Europe would be a problem to get some Siemens connectors wink , but for those folks who are a bit "off the place", like you, this is really a -G-R-E-A-T- piece of advice. I wouldn't find out such thing as to use old CD cables as connectors... I take off my hat before you. Congrats
Idea PS: If you like making accessories to your phone, you might try to make a LED lamp. I made it for myself, too, and its a great thing whien you need light. You just need a LED diode and a connector...
Regards and go on, you are REAL SiemensManiac
Ičo
M35i -> S65 patch-free (okrem zvuku fotaku)
+lampicka+DCA-540
"Nothing shocks me. I'm a scientist." Indiana Jones
... o zážitok viac. http://www.plusko.net/
View user's profile Send private message Yahoo Messenger
ahmedhosni2002
PostPosted: Mon Jul 03, 2006 4:47 pm    Post subject: Reply with quote
hi iko,
I'll make a white LED lamp. Now I have a spot of 2 Ir LEDs & it's great for night vision through the phone camera.
I made an IMS-700 3.5mm connector with-----> Karaoke effect (on/off) Wink
just solder a switch to pin "9" then, switch on=normal voice, switch off=Karaoke Smile
BunGee
0.52 SMM
PostPosted: Mon Jul 03, 2006 5:01 pm    Post subject: Reply with quote
o co tady de???
Může-li se pokazit více věcí za sebou,
pokazí se v nejnevhodnějším pořadí
Ericsson T10=>
Siemens M65=>Fuj Blokia 3410(nenavidim blokie)=>SXG75/SVN 22 + Blesk + 1GB SanDisk + DCA-540 + ASUS P535
Vodafone 4ever
iko
PostPosted: Mon Jul 03, 2006 5:11 pm    Post subject: Reply with quote
bungee1 wrote:
o co tady de???
Nevies anglicky? Laughing
Ide o to, ze chalan z Egypta ma Siemensa cx75 a robi si k tomu rozne hovadinky ako jack konektor, atd. No a v Egypte sa vraj tazko zhanaju Siemens konektory tak prisiel na to, ako si pomerne jednoducho a svojpomocne vyrobit vlastne (kable z CD prehravacov, take 14-zilove).
No a nepochval taku kreativitu.
Tomu hovorim SiemensManiactvo! wink
Ičo
+lampicka+DCA-540
PostPosted: Sat Jul 08, 2006 2:04 pm    Post subject: Reply with quote
Great idea, very impressive. Applause
Onecar
veterán
veterán
10894.00 SMM
PostPosted: Sat Jul 08, 2006 3:30 pm    Post subject: Reply with quote
Great job, r3sp3ct man wink.
Onecarovo Portfolio & Blog
Mizím jinam, ale SM zůstanu věrný -> Motorola MPx220 @ 240 MHz @ WM2003SE - Kingstone 512MB miniSD Card
View user's profile Send private message Visit poster's website AIM Address Yahoo Messenger MSN Messenger
Mio
10930.24 SMM
PostPosted: Sat Jul 08, 2006 4:21 pm    Post subject: Reply with quote
My firt reaction was: "Jesus fucking Christ".
But, great solution if no other way.
Connectors are now available here for 1EUR.(No single conectors, but x55 HF). Maybe someone from here is going to Egypt this summer, and could take few for you.
N95-8GB
Miroslav Šůs
PostPosted: Sat Jul 08, 2006 4:47 pm    Post subject: Reply with quote
Nice job. You're really creative. Applause Applause
C25 -> C35i -> C45 -> M55 -> MC60 -> CX65 -> SXG75(fw22) + 1GB RS-MMC + IMS 700 + HHB 700 + S75(fw40) na porovnani
ahmedhosni2002
PostPosted: Sun Jul 09, 2006 1:14 am    Post subject: Reply with quote
Even if connectors are available in Egypt, they will not sell too much here.
I make some 3.5mm adapters & DCA-540 for my friends
If someone is visiting Egypt, please give me some Laughing & I'll take you in a tour here
Reply to topic     Forum Index -> Non Czech Languages Here All times are GMT + 1 Hour
