CRAZYTAN 666 začátečník
Posted: Sat Jul 15, 2006 10:51 pm Post subject: Graph patch manager |
nevite jak nahrat do tel.graph patch manager.po nalezeni site pip a chcip |
D4X (o(^^)o)
Posted: Sun Jul 16, 2006 10:31 am Post subject: |
a mas GPM pro svuj MP? (master patch) je vic verzi... _________________ -> Nokia Lumia 800 |
Posted: Sun Jul 16, 2006 12:23 pm Post subject: |
TO JE JASNE ZE MAM SPRAVNOU VERZI AKORAT PO NALEZENI SITE PIP A CHCIP.MAM MP OD AVKIEVA |
D4X (o(^^)o)
Posted: Sun Jul 16, 2006 2:13 pm Post subject: |
mno... co na tohle rict me pomohlo prehrani FF zalohy ze SM este muzes zkusit jiny MP 8) _________________ -> Nokia Lumia 800 |
marcobubo3 začátečník
Posted: Mon Jul 17, 2006 9:28 pm Post subject: Re |
Mam podobny problem s GPM pre CF75v22.telefon pipne a chcipne.ci mam spravnu v.gpm neviem,nevyznam sa v tom tak dobre,helpne mi niekto?inak problem mi robi aj API,ten hadze chyby,zrejme to bude nim.vraj je api univerzalny,tak neviem |
D4X (o(^^)o)
Posted: Tue Jul 18, 2006 11:14 am Post subject: |
pokud mas MPv5 tak si stahni GPM pro MPv5
a kdyz mas MPv3 RC2 #114 tak zase verzi pro MPv3...
tyhle patche by se mely davat na cisty FW protoze kdyz uz mate napatchovano tak to muze delat neplechu... a kdyz ani tak nepujde tak mas bud spatne knihovny nebo je to telefonem.. jak uz sem psal v mem pripade to bylo spatnou FF... _________________ -> Nokia Lumia 800 |
Posted: Tue Jul 18, 2006 12:23 pm Post subject: Re |
Daval som to aj na cisty fw a nepomohlo.a mp mam v5 a gpm v3.1,problem je v tom,vraj MPv3 pre moj telef.nezozeniem a gpm vyssej verzie som nenasiel... |
D4X (o(^^)o)
Posted: Tue Jul 18, 2006 12:50 pm Post subject: |
Graph patch manager verze 3.1 av
Pomocný patch
Aplikovat na Master Patch v5 by avkiev
Pomocný patch
Aplikovat na Master Patch v3 RC2 #114 _________________ -> Nokia Lumia 800 |
Posted: Tue Jul 18, 2006 4:50 pm Post subject: Re |
A pomocny patch je API,ci ktory? |
D4X (o(^^)o)
Posted: Tue Jul 18, 2006 5:52 pm Post subject: |
Grapg patch manager je ten pomocny patch  _________________ -> Nokia Lumia 800 |
Posted: Tue Jul 18, 2006 6:41 pm Post subject: Re |
Takze mam MPv5 by avkiev a mal som stiahnuty aj gpm 3.1av,ale robi mi to aj tak.prosim ta,pozri sa na do sekcie patchov na ten gpm 3.1av,lebo mne sa zda, ze je to iba 3.1... |
D4X (o(^^)o)
Posted: Tue Jul 18, 2006 9:12 pm Post subject: |
se tam podivej sam ne
pokud ti to nevali tak mas asi holt smulu... pokud mas vsechno co potrebujes... knihovny, mp, gpm, api tak by ti to melo jet... _________________ -> Nokia Lumia 800 |
Posted: Tue Jul 18, 2006 9:43 pm Post subject: Re |
no ved ja som odtial stahoval gpm,ale nejak sa mi to nezda.inak k api,tie mi hadzu chybu,ze sa nejake bloky nenasli... |
