:: View topic - flash update cfx65
flash update cfx65
dvcompt
33.64 SMM
PostPosted: Thu Jul 20, 2006 9:39 am    Post subject: flash update cfx65 Reply with quote
stahnul jsem si firmware pro cfx65, ale nevím jakým softwarem to tam nahnat. dekuji.
prihlaseny
PostPosted: Thu Jul 20, 2006 7:42 pm    Post subject: Reply with quote
radsej sa nijakym sposobom nepokusaj nahravat FW do telefonu,cfx65 je "nepreskumana cast sveta", jak ho zabijes, bude dead Hand
dvcompt
33.64 SMM
PostPosted: Thu Jul 20, 2006 9:26 pm    Post subject: Reply with quote
priznam se ze tomuhle prave muze pomoci jen ten flash, cim to tam tedy nahrnu?
prihlaseny
PostPosted: Thu Jul 20, 2006 9:27 pm    Post subject: Reply with quote
potrebujes soft pre sony ericsson, datovy kabel pre c62, radsej to daj do servisu za 200 sk Smile na boxe to spravia
ajko
PostPosted: Thu Jul 20, 2006 9:37 pm    Post subject: Reply with quote
si si s tym kablom od SOny ericssonu isty??? ja s tymto mobilom nemam skusenost ale sa mi to nezda aby na Siemens isiel kabel od SE Rolling Eyes
aj ked viem ze je to prebraty telfon ale Rolling Eyes
prihlaseny
PostPosted: Thu Jul 20, 2006 9:38 pm    Post subject: Reply with quote
nie kabel, kabel je dca-510 ale upraveny pre c62, a flashoavci program potrebuje pre SE
ajko
PostPosted: Fri Jul 21, 2006 8:03 am    Post subject: Reply with quote
jeee sorry som to vecer uz unaveny zle precital Embarassed
no stava sa Anxious
