:: View topic - Email na s65.....Orange-sk
De_De
PostPosted: Wed Aug 30, 2006 9:57 pm    Post subject: Email na s65.....Orange-sk Reply with quote
Mohli by ste mi niekto pomôct nastavin email na telefon siemens65?....operator mam Orange-sk a mam Primu
Siemens S65
tomaslanger
PostPosted: Thu Aug 31, 2006 8:57 am    Post subject: Re: Email na s65.....Orange-sk Reply with quote
nenastavuje se to podle operatora, ale podle serveru, kde mas e-mail...
C35i -> M35i -> A60 -> CSL65 -> S65
De_De
PostPosted: Thu Aug 31, 2006 11:23 am    Post subject: Reply with quote
no ale to praveze vôbec neviem jak mam spravit......napr mailovu schranku mam na de_de@centrum.sk........jak sa to da podla toho zistit
Siemens S65
14311.82 SMM
PostPosted: Thu Aug 31, 2006 11:50 am    Post subject: Reply with quote
jedna z možností je použiť Konfigurátor nastavení cez SMS Arrow http://www.benq-siemens.com/cds/frontdoor/0,2241,sk_sk_0_142300_0_xcs%253A139439_xcp%253A,00.html
beardie
7865.50 SMM
PostPosted: Thu Aug 31, 2006 12:02 pm    Post subject: Reply with quote
cez primu nejde gprs,takze maily nepojdu
aspon tak to fungovalo ked som bol naposledy na slovensku
De_De
PostPosted: Thu Aug 31, 2006 12:24 pm    Post subject: Reply with quote
no vidno ze uz si tu nebol hooooooooooooodne davno.......potom ako by sa asi dali posielat mmsky?..... GPRS urcite ide cize nehladaj v tom zavadu
Siemens S65
De_De
PostPosted: Thu Aug 31, 2006 12:33 pm    Post subject: Reply with quote
nic..........skusal som to tak nastavit a nic....neodoslalo.......neviem co s tym......ale aj tak dik
Siemens S65
zoleeexx
PostPosted: Thu Aug 31, 2006 12:34 pm    Post subject: Reply with quote
GPRS na primu neide, funguje len na APN mms, ale to mozes pouzivat len na posielanie MMS. takze email s primou v ziadnom pripade Shame on you
Sefinko
elfmaster
elfmaster
Location: Strážske (Okolie) Telefon: CSL65v53 EL71v45 + 1GB Kingston (c) Benlux
6980.53 SMM
PostPosted: Thu Aug 31, 2006 12:36 pm    Post subject: Reply with quote
beardie ma pravdu, cez primu nejde primat maily...
14311.82 SMM
PostPosted: Thu Aug 31, 2006 12:47 pm    Post subject: Reply with quote
ale GPRS nie je jediná cesta ako sa dostať k mailom, aj cez WAP sa dá, ak nie priamo, okľukou, a PRIMA má WAP Shame on you
Inak - veľká škoda Brick wall Brick wall Brick wall že na SLovensku sa na predplatených kartách zatiaľ nedajú využívať dátové služby GPRS-EDGE, inde je to bežné, dúfam, že s tým príde nový operátor O2 a možno aj starci TM a OR sa rozhýbu. Think
De_De
PostPosted: Sat Sep 02, 2006 12:09 pm    Post subject: Reply with quote
cize maily urcite cez primu nepojdu.......tak to mam chapat?
Siemens S65
pluto3
Phone: SiemensSK65
9404.40 SMM
PostPosted: Sat Sep 02, 2006 12:17 pm    Post subject: Reply with quote
nastavení e-melů na S65 je jednoduchý šak se tam napíše jen méno Email heslo pop3 nebo Imap4 servr SMTPčko pár portů a je to
Siemens S65 FW58 zcizen
Dále: A35, C25, C55, M55, M75
14311.82 SMM
PostPosted: Sat Sep 02, 2006 12:27 pm    Post subject: Reply with quote
Na Prime asi priamo cez emal klienta nie, lebo to vyžaduje obvykle GPRS, a nie WAP. Dalo by sa inak a to cez WAP, ale cez nejakú WAP stránku, ktorá umožňuje prístup k mailom. V T-Mobile na Easy je to možné, lebo TM WAP email dokáže ísť nielen na vlastné stránky ale aj iné, teda aj centrum.sk Hand
Alebo maily z centrum.sk prepopielať na orangemail.sk a tam sa dá k nim dostať aj cez Primu a WAP.
Alebo najvýhodnejšie: s Primou prejsť na najnižší paušál a vtedy je prvých 30 sekúnd na WAP zadarmo a za ten čas sa dá niekedy dosť urobiť, potom zostať offline a ak treba zase sa pripojiť, resp. si aktivovať aj Orange World avtedy je 10MB na mesiac za sumu niečo vyše 100 Sk a to by malo na bežné veci stačiť, alebo presť k T-Mobilu, kde to všetko vyjde pohodlnejšie a lacnejšie.
De_De
PostPosted: Sat Sep 02, 2006 6:39 pm    Post subject: Reply with quote
Oukej dakujem vam za info
Siemens S65
PostPosted: Sat Sep 02, 2006 7:53 pm    Post subject: Reply with quote
musis mat zaplateny datovy program inac nemas nad cim rozmyslat inak sa to neda ani cez CSD.
