:: View topic - !!! EL71 Uspesne napalenie !!!
Goto page 1, 2, 3  Next
This topic is locked: you cannot edit posts or make replies.     Forum Index -> Třída E
PostPosted: Mon Sep 04, 2006 9:14 am    Post subject: !!! EL71 Uspesne napalenie !!! Reply with quote
Takze napalenie alebo prepalenie softu na EL71, da sa urobit pomocou noveho WinSwup v4.18. Skusam potom dam vediet ako na tom je.
mao7
PostPosted: Mon Sep 04, 2006 3:01 pm    Post subject: Re: !!! EL71 Uspesne napalenie !!! Reply with quote
odkial mas telefon od operatora a od akeho
M35 2x => S55 fw 90 => A52 => EL 71 od ORANGE
PostPosted: Mon Sep 04, 2006 8:22 pm    Post subject: Reply with quote
Nerobim na svojom. Nemam EL71. Robim na inych. ROZNE...
PostPosted: Mon Sep 04, 2006 10:11 pm    Post subject: Reply with quote
Podarilo sa Ti prehrat Wiswup FW na customizovanom telefone od Orange?
PostPosted: Tue Sep 05, 2006 6:32 am    Post subject: Reply with quote
Zatial na dvoch. Skusam dalej...
PostPosted: Tue Sep 05, 2006 7:06 am    Post subject: Reply with quote
Ked to ide na dvoch,pojde to aj na ostatnych.
Podel sa o skusenosti. S akym kablom to robis,pri akych nastaveniach Winswupu,aky FW nahravas, v akom stave je telefon po prepaleni FW (customizacia,stabilita,atd)
sssugi
667.50 SMM
PostPosted: Tue Sep 05, 2006 12:43 pm    Post subject: Reply with quote
super takže to ide Applause už mi nič nebráni si ísť do orangeu po neho Very Happy
Siemens M65+S65+C55+DCA 510
deglaser
91.00 SMM
PostPosted: Wed Sep 06, 2006 8:17 am    Post subject: Reply with quote
Ja skousim ozivit el71 winstupem a porad mi to nejde.
PostPosted: Wed Sep 06, 2006 9:44 am    Post subject: Reply with quote
No su troska malicke problemy, skusam dalej, ale urcite dam vediet ako na to. 4-uspech, 1-neuspech total KO.
sssugi
667.50 SMM
PostPosted: Wed Sep 06, 2006 2:30 pm    Post subject: Reply with quote
FW nahrávaš pomocou winswupu?originálne updaty nejdú?
TiGeRz23
PostPosted: Wed Sep 06, 2006 10:12 pm    Post subject: Reply with quote
no kde mame ten navod ? Crying or Very sad
BENQ SIEMENS EL71
PostPosted: Thu Sep 07, 2006 6:22 am    Post subject: Reply with quote
Ja len origo WinSwup subory, original update som neskusal. TiGeRz23 navod dam, az ked to bude minimalne 99% -uspesne
mmd
PostPosted: Fri Sep 08, 2006 10:12 pm    Post subject: Reply with quote
Ja mam ELF 1 /od ORANGE/ a ani orig firmware ani WinSwup mi nechcu ist! WinSwup mi pise : Could not open Comport for BFC-Lib, maybe Comport is in use.
Je mozne ze je to tym, ze som uz 3x zadal zle kod telefonu? /ma to vplyv na update firmware?/
TiGeRz23
PostPosted: Sat Sep 09, 2006 7:44 am    Post subject: Reply with quote
mario_liptov wrote:
Ja len origo WinSwup subory original update som neskusal. TiGeRz23 navod dam az ked to bude minimalne 99% -uspesne
daj link na nejaky WinSwup subor, alebo to konvertujes ? Ak ano akym programom ?
BENQ SIEMENS EL71
PostPosted: Sat Sep 09, 2006 5:47 pm    Post subject: Reply with quote
Arrow http://www.siemensmania.cz/dnld.php?id=23188
This topic is locked: you cannot edit posts or make replies.     Forum Index -> Třída E All times are GMT + 1 Hour
Page 1 of 3
