:: View topic - Fss ini, map
Fss ini, map
RDan
PostPosted: Thu Sep 14, 2006 8:38 am    Post subject: Fss ini, map Reply with quote
Prosim kde sezenu FFSini a map soubory na s75 fw40?
Drobcek9056
7860.92 SMM
PostPosted: Thu Sep 14, 2006 8:42 am    Post subject: Re: Fss ini, map Reply with quote
tak pokial niesu tu na Siemensmanii v sekcii Zalohy pameti, tak asi uz nikde,alebo jedine na ruskych strankach,ale aj to keby tam boli,boli by uz aj tu.
momentalne SL55 Smile
RDan
PostPosted: Thu Sep 14, 2006 11:31 am    Post subject: Reply with quote
A musí být ty soubory special pro cz telefon nebo nevadi kdyz tam dam rusky nebo nemecky?
Drobcek9056
7860.92 SMM
PostPosted: Thu Sep 14, 2006 11:36 am    Post subject: Reply with quote
tak to ti neviem,ale tusim FFS Init nahrava len standart mobilu, t.j. obrazky,melodie a tak,takze tomu by to teoreticky nemalo vadit.
// EDIT : tu mas FFS Init zo SM : Arrow http://www.siemensmania.cz/download.php?file=/backups/S75_FF_.rar
RDan
PostPosted: Thu Sep 14, 2006 11:40 am    Post subject: Reply with quote
A nevis pros mi pise Siemens EEPROM tool pri spusteni Chyba: Unexpacted error ??
Drobcek9056
7860.92 SMM
PostPosted: Thu Sep 14, 2006 11:43 am    Post subject: Reply with quote
Je tu uz nejaky TOPIC,kde je to rozobrate,tak skus pohladat. Cital som ze to davanie FFS Init do mobilov S75,SL75,SXG75 a uz neviem ake modely,je trosku inaksie ako u starsich x75 a x65.
Treba hladat,tusim aj clanok bol o tom pisany. Smile
