:: View topic - problem pri prehravani noveho FW
forcius
PostPosted: Fri Feb 23, 2007 10:35 pm    Post subject: problem pri prehravani noveho FW Reply with quote
Mam kabel DCA510, prerobil som ho cez odpory a hlasy sa mi ako DCA100, skusal som prehrat FW a stale mi hlasi ze
"Software update denied by mobile" telefon ma menu T-mobile Sk....mozete mi poradit?
PostPosted: Fri Feb 23, 2007 10:38 pm    Post subject: Reply with quote
Nemas zavedeny SKEY.
forcius
PostPosted: Sat Feb 24, 2007 3:02 pm    Post subject: Reply with quote
vygeneroval si HAS a ESN cez bsreader, a papua mi nevygeneruje SKEY, pritom konektivita tu je,lebo IMEI telefonu nacita v pohode...v com to asi bude?
PostPosted: Sat Feb 24, 2007 3:06 pm    Post subject: Reply with quote
Papua vygeneruje SKEY aj bez pripojenia telefonu zadal si ESN z Bsreadera takto:
ABCDEF12=->12EFCDAB
Ak budes mat problem posli mi veci do SZ ja ti to vypocitam.
granko
PostPosted: Sat Feb 24, 2007 7:16 pm    Post subject: ten isty problem Reply with quote
mam aj ja,neviem cim to je
C45-M35-M50-CX65-CX70-BS EL71 fw.38-Dekustomizácia-a to Vám je parádička+256MB.
PostPosted: Sat Feb 24, 2007 7:22 pm    Post subject: Reply with quote
Skusil si novsiu verziu PU? Inac plati to co som napisal v predchadzajucom prispevku na spodku.
forcius
PostPosted: Sat Feb 24, 2007 8:23 pm    Post subject: Re: ten isty problem Reply with quote
kde si kupoval EL71? aky mas FW?
granko
PostPosted: Sat Feb 24, 2007 9:25 pm    Post subject: TO FORCIUS Reply with quote
Kupeny bol v orange,teraz mam v.38 ale to je po preflesovani a odstraneni orange blbosti.
forcius
PostPosted: Sun Feb 25, 2007 12:13 am    Post subject: Reply with quote
tak uz mam vygenerovane aj zavedene SKEY, disky v explolery su odryte...pri nhravani noveho FW mi stale vypise
"30b Software update denied by mobile"
co to moze znamenat...?
granko
PostPosted: Sun Feb 25, 2007 8:10 am    Post subject: re forcius Reply with quote
A ako sa ti to podarilo? mne to stale nechce generovat S key.
PostPosted: Sun Feb 25, 2007 8:13 am    Post subject: Reply with quote
POzrel si to co som ti poslal do SZ? Ak mozes z blizka odfotit z telefonu co vygeneroval bsreader tak mi to posli.
