:: Zobrazit téma - help with siemens c65
Odpovědět na téma    Obsah fóra -> Non Czech Languages Here
andrei3288
Založen: 14. 03. 2006
PříspěvekZaslal: st listopad 01, 2006 3:47 pm    Předmět: help with siemens c65 Odpovědět s citátem
I have a siemens c65 wich doesn`t work. i think the software is the problem so i want to rewrite it. but i have a problem... i have made it`s testpoint and in vlkay when i enter chaos boot or password bot (it doesn`t have c65 testpoin) the phone doesn`t connect to the computer. The testpoint is very good because when i enter password boot it shows testing your connection speed but i can`t do nothing on it because it disconnects. Please help me!!! I repeat the phone is not working so i can`t generate it`s codes without making testpoint. What should i use? Thank You
siemens m55 -> nokia 6230 -> siemens s65 v58 -> siemens sl55 -> siemens cx65 -> siemens sl75 v47
Zobrazit informace o autorovi Odeslat soukromou zprávu Odeslat e-mail Yahoo Messenger
andrei3288
PříspěvekZaslal: so listopad 04, 2006 5:16 pm    Předmět: Odpovědět s citátem
Sad nobody can help me? Neutral
xXxTRA^^
Založen: 13. 07. 2006
5896.92 SMM
PříspěvekZaslal: so listopad 04, 2006 5:22 pm    Předmět: Odpovědět s citátem
you must abort tespoint with soft pencil
IMG Hosting | iProtebe
Založen: 11. 08. 2005
132978.34 SMM
PříspěvekZaslal: so listopad 04, 2006 5:55 pm    Předmět: Odpovědět s citátem
2xXxTRA: on x65 and x75 isn´t cutting testpoint like on older phones.. testpoint is connect two places with resistor (x65) or diode (x75) and testpoint is aborted when you disconnect this diode (or resisor)
Odpovědět na téma    Obsah fóra -> Non Czech Languages Here Časy uváděny v GMT + 1 hodina
