:: View topic - [CX65]PROBLEM WITH PATCHING / PROBLEM Z PATCHOWANIEM
Reply to topic     Forum Index -> Non Czech Languages Here
meciu99
PostPosted: Sat Nov 04, 2006 7:34 pm    Post subject: [CX65]PROBLEM WITH PATCHING / PROBLEM Z PATCHOWANIEM Reply with quote
Miałem problem z telefonem,ciągle sie wyłączał więc dałem go do servisu. Wymienili mi płytę główną i wgrali mi softa 50. Próbowałem odczytać SKEY i BOOTKEY ale nie idzie. Próbowałem VKLAY, x65 PATCHER, PAPUA UTILS
MAM ORYGINALNY KABEL DCA-500 + Zasilanie
I was have a problem with my phone, sometimes he shut down when battery is full, after that i go to service in POLAND & he was repaired, they give me a new mainboard and they installed a firmware v50. I tried to crack bootcore because i want to install patches. In VKLAY (last icon, on firmware 25) cannot find SKEY, on x65 FLASHER TOO Neutral, and papautils TOO! I have oryginal DCA-500 cable with plugged-in battery 4,5V. Service mode works NORMALLY
PLEASE, HELP ME
ps.
Sorry for my bad ENGLISH. I'm from POLAND
//Moved from „x65, x70“; jenda.69
jenda^^
PostPosted: Sat Nov 04, 2006 7:47 pm    Post subject: Reply with quote
Bootcore patching is only for FWs upto 25. You have fw50, so you can do this:
http://www.siemensmania.cz/forum/viewtopic.php?t=19643
Teď mám: Nexus S
meciu99
PostPosted: Sun Nov 05, 2006 12:23 am    Post subject: Reply with quote
i cant find skey and bothey. I try on px65v4 px5v5, px75v1. The newers x65 flasher and newest Papua Utils.
PLEASE, HELP
MarioWRC
PostPosted: Sun Nov 05, 2006 1:23 pm    Post subject: Reply with quote
PLEASE, HELP
a probowales VIPERGSM to cos jak px75v1 ale liczy w ciagu 10 sekund poszukaj sobie na siemensmani.cz ja mialem to samo u siebie jak mialem S65 i tylko VIPERGSM policzyl kody sprobuj moze da rade.
EF81 v58 + Patche
meciu99
PostPosted: Sun Nov 05, 2006 6:21 pm    Post subject: Keys Reply with quote
Embarassed no nie działa również, nie znajduje kluczy.
z softem v16 też nic nie wykrywa...
Please HELP ME, i cannot find skey and bootkeyEmbarassed .
I'm installed now firmware v16 and its doesn't work too Crying or Very sad
PLEASE HELP
MarioWRC
PostPosted: Sun Nov 05, 2006 10:15 pm    Post subject: Re: Keys Reply with quote
PLEASE HELP
Mam rozwiazanie Very Happy . Musisz zrobic backupa przez V_Klay z TestPointem pozniej wrzucic tego FF do Smeltera i on policzy kody i po klopocie Very Happy
EF81 v58 + Patche
meciu99
PostPosted: Sun Nov 05, 2006 10:18 pm    Post subject: help Reply with quote
Mógłbyś mi to napisać dokładniej, lub skotantkuj sie ze mną na gg. Mój nr to [url]7953332[/url]
Cieniu
Location: -Poland- .:Szczytno:. Telefon: EL71 v45 PL I Csl65 v53
PostPosted: Sun Nov 12, 2006 2:16 pm    Post subject: Reply with quote
MarioWRC
co ty za głupoty wypisujesz ??
www.forum.siemensiak.pl
Cieniu
PostPosted: Sun Nov 12, 2006 2:18 pm    Post subject: Reply with quote
a wiesz co mi sie zdaje ze cos z bcore jest lub z otp
wejdz w service mode i daj tu loga z info
MarioWRC
PostPosted: Sun Nov 12, 2006 5:59 pm    Post subject: Reply with quote
Cieniu wrote:
MarioWRC
Glupoty to ty sobie wypisujesz!!! A tak pozatym to jak zrobi FF i policzy kody w smelterze to bedzie mogl wrzucic SKEY i po klopocie ze wszystkim. Bedzie mogl sie laczyc z vklayem i innymi progsami bez zadnego loadera !!!
EF81 v58 + Patche
Cieniu
PostPosted: Sun Nov 12, 2006 7:23 pm    Post subject: Reply with quote
chłopie jak ma zczytac ff jak nie moze sie połaczyc ale to jest wogule bez sensu ty jestes pojebany
zrób mu TP i bedzie git ale mi sie zdaje ze niemasz bcore w telu miałem jeden taki przypadeg w c75 robili go wserwisie potem miałem go troszeke ztuningowac i niemogłem nic zczytac wiec sie niejebałem dałem TP nowy bcore i elegandzko wszystko smigało
MarioWRC
PostPosted: Mon Nov 13, 2006 9:46 am    Post subject: Reply with quote
A co ja kurwa napisalem pojebie, to samo ze test point i bedzie git Brick wall Twisted Evil a ze ty czytac nie potrafisz to juz nie moje sprawa. Niechce mi sie z toba juz gadac.
EF81 v58 + Patche
Cieniu
PostPosted: Mon Nov 13, 2006 11:52 am    Post subject: Reply with quote
hłopcze co ty mi tu pierdolisz pracowałem w servisie gsm i troszke na ten temat wiem wiec jak chcesz byc mondzejszy to umyj se cycki i niepiesz głupot bo z tp moze zczytac kody dac nowy bcore i spokuj a ty o jakims przeliczaniu kodów w FF ic sie umyj i wiecej niepisz a jak chcesz byc mondzejszy to zapraszam www.forum.siemensiak.pl
meciu99
PostPosted: Mon Dec 18, 2006 5:47 pm    Post subject: dalej nic :/ Reply with quote
tutaj jest log z papua utils 0.9.1
Erhalte die Keys vom Telefon...
Erhalte Informationen:
Model: SIEMENS CX65 16 lg4
Telefon ist im "Normal Mode"
IMEI: 353538003059534
SecurityStatus: CustomerMode
HWID: 320
Akkuspannung: 4084 mV.
ESN: 7509A335
HASH: 75AA36FF2430979D622E9645DAC46BBA
Berechne die Schlüssel...
Schlüssel wurden nicht gefunden!
Starte den "Service Mode"...
Press Red key !
Autostart...
Boot nicht geladen!
Telefon ist im "Normal Mode"!
Telefon wird abgestellt...
Bitte nochmal versuchen.
Press Red key !
Autostart...
ÜTransfer boot...
Gestartet im "Service Mode" Ok
Erwarte Start des Telefons...
Telefon ist im "Service Mode"
IMEI: xxxxxxxxxxxxxxx
HWID: 320
Akkuspannung: 4093 mV.
Cieniu
PostPosted: Tue Dec 19, 2006 5:32 pm    Post subject: Reply with quote
no zrób nowe bcore i koniec tematy w pu masz opcje nowe bcore poszukaj filmiku allbugs...
i według niego to zrobisz i bedzie spoko poniewaz tak sie dzieje bo teraz maja nowe jakies kombinacje kodowania :] i terazniejsze pu tego niekuma i trzeba zrobic stare nowe bcore
Reply to topic     Forum Index -> Non Czech Languages Here All times are GMT + 1 Hour
