:: View topic - Channel Banner
Channel Banner
ccd98
8031.04 SMM
PostPosted: Sat Mar 29, 2008 2:25 pm    Post subject: Channel Banner Reply with quote
http://forum.siemens-club.org/pda/viewtopic.php?TopicID=66170
(jestli na té stránce najdete odkaz, co připomíná slovo "Archiv", tak si to můžete i stáhnout Mr. Green )
Na patches.siemens-club.org je patch na FW47 i FW52; ten z toho Archivu mi funguje na 47 taky OK)
-jinak je to docela vychytávka, spustíte Elf ChanBannerGUI a nastavíte zakázané kanály, čímž telefon může odfiltrovat nejvíce "řvoucí" BTSky a naopak nastražit uši na nějaké vzdálené či neznámé.
BTW k temu Konci - asi je to opravdu vážné (protože kdyby se napsalo, že se SM ruší už k 1.4.2008, tak... Mr. Green )
S LXXV
132978.34 SMM
PostPosted: Sat Mar 29, 2008 4:20 pm    Post subject: Reply with quote
Wow, to jsem nečekal... skusím, odkud maximálně chytnu BTSky.. Smile
Duku
uživatel roka 2008
uživatel roka 2008
Phone: EL71v45
28.71 SMM
PostPosted: Sat Mar 29, 2008 4:26 pm    Post subject: Reply with quote
Nechapem...ako sa to da vyuzit?
Tu je patch na E71 a EL71.
>Daruj krv<
delpierwin
519.20 SMM
PostPosted: Sat Mar 29, 2008 6:25 pm    Post subject: Reply with quote
I'm sorry, channel banner patch, what does exactly this patch for? Very Happy
SiemensXP | My Blog
BenQ Siemens EL71 v45 Diamond Style
Siemens ME45 Standard
Siemens A70 Almost die -- dying
Siemens S57 v17 Standard
Siemens SX1 v15 Cristal 2+
Siemens M65 Windows 7 v1.1
Siemens S75 v47 Katie Meula Case
HTC Touch Pro - Timolol's WM6.5 Stock Like ROM
ccd98
8031.04 SMM
PostPosted: Sat Mar 29, 2008 9:29 pm    Post subject: Reply with quote
delpierwin:
You can BAN (=disable) certain channels (every Base-Transceiver-Station´s antenne has its channel); it is useful in two (or even more;)) causes:
1) if you are receiving signal from two BTSs which have near the same signal, you can prefer only one of them by disabling the channel of the other (of course that these 2 BTS mustn´t have the same channel).
2) if you want to explore some further BTSs with bad signal, that you normally can´t see (because the cell-phone is receiving signal from the nearest BTSs by default) - you simply disable the channels of the "strongest" BTSs and receive the signal from "weakest". Wink
Duku:
Využití je prakticky nulový, ale zrovna u mě dneska ne - včera jsem náhodou logoval BTSky (je k tomu potřeba aplikace a patch) a v logu jsem objevil CID (cell id - stručně každá anténa na vysílači má svoje číslo), co není na seznamu (gsmweb.cz).
Dneska jsem se vypravil na to samé místo, kde jsem to CID zachytil, otevřel v servisním menu "Neighbour cells" a znovu tam to CID bylo vidět, i s uvedeným kanálem. Protože ale nebylo na výchozí pozici, za použití tohoto ELFu jsem ho tam úspěšně "dokopal" zakázáním okolních silnějších kanálů.
No a voilá, potom už stačilo jen to CID "prozvonit" (=vytočit stodvanáctku a zavěsit ještě než se to spojí; (btw snad jim to nevadí Twisted Evil Think ) a v servisním menu se objevil i údaj o tom, jak je vysílač s tím CID daleko
(to se dělá jen tehdy, když jde o cizího operátora; v opačném případě můžeš prozvonit sám sebe).
No a tohle když se udělá na třech místech pár kilometrů od sebe, tak člověk získá určitou představu, kde je ten vysílač umístěný a příště už ho doloví. Hand
S LXXV
132978.34 SMM
PostPosted: Sat Mar 29, 2008 11:04 pm    Post subject: Reply with quote
Heh, trvalo mi, než jsem přišel na to, jak to používat... Mr. Green
Ten Channel je CH v Neighbours Cell Smile a mačkáním čísel se v tom "seznamu" kanálů dá i vyhledávat...
chytám s tím dost BTSek, ale všechny jsou jen z blízkýho okolí...
no, musím s tím někam vyjet... pamatuju, jak jsem s java aplikací BTS chytal BTSky na Velkém Kosíři (hora) a chytnul jsem i BTSku, co je i v Olomouci, nedaleko mého bydlišetě... Smile bylo to na vzdálenost přes 20 km
někdy to zase musím vyzkoušet, s tímhle elfem to bude lepší...
delpierwin
519.20 SMM
PostPosted: Sun Mar 30, 2008 7:50 am    Post subject: Reply with quote
ccd98 wrote:
delpierwin:
Ow i see, i'm adding clear info, in BTS there are 2-3 antennas, each defined as a cell, and a cell could contain 2-4 channels (also called ARFCN). So by judging strong or weak signal, it's should referred to a cell, not a channel. But still we do initialization on a channel not a cell Very Happy
Thank You for Your explanation ccd98.
SiemensXP | My Blog
