:: View topic - Extra info v progress bare
FredyKruger
PostPosted: Fri Mar 23, 2007 10:05 pm    Post subject: Extra info v progress bare Reply with quote
Čaute,chcel by som si dať tento patch na extra info pri posielaní suborov cez bt ale samotný ked ho tam nahodím tak telefon pxuje,chcem sa spýtať aké patche sú k nemu ešte potrebné mať.Dík za rady lebo som v tom začiatočník Embarassed
siemens A55-->siemens S55-->siemens S65 +mp3+DCA500+handsfree
PostPosted: Sat Mar 24, 2007 9:57 am    Post subject: Reply with quote
Nutné je mít MasterPatch a všechny patche nutné pro jeho chod. A ty jsou taky pro každou verzi MP jiné. Co máš za fw?
FredyKruger
PostPosted: Sat Mar 24, 2007 4:07 pm    Post subject: Reply with quote
mám s65 fw58
mart22
elfmaster
elfmaster
56669.28 SMM
PostPosted: Sat Mar 24, 2007 4:09 pm    Post subject: Reply with quote
asi jsi nehledal?
Máš Disable Retarget Exit? http://patches.kibab.com/patches/dn.php5?id=3719
FredyKruger
PostPosted: Sat Mar 24, 2007 9:28 pm    Post subject: Reply with quote
Hmm takže tam mám dať ten master patch mpv14 či ako to je,function library,ten retarget exit a samotný patch na extra info? Shocked
MikeMaster
4379.18 SMM
PostPosted: Mon Mar 26, 2007 10:06 am    Post subject: Reply with quote
To mart22: Pro patch Extra Info on Progress Bar je nutný mít Disable Retarget Exit ??? Odkdy ? Shocked
mart22
elfmaster
elfmaster
56669.28 SMM
PostPosted: Mon Mar 26, 2007 12:06 pm    Post subject: Reply with quote
od tý doby co existuje.? bez něho mi to na s65 nešlo (pozná se to podle posledního EXITu: Retarget_Exit wink ).
PostPosted: Mon Mar 26, 2007 3:35 pm    Post subject: Reply with quote
Já ho mít taky musím 8)
MikeMaster
4379.18 SMM
PostPosted: Tue Mar 27, 2007 10:24 am    Post subject: Reply with quote
Tak alespoň ten patch Disable retarget exit k něčemu je...
