:: View topic - SXG75 "Factory Test Mode" Problem
Reply to topic     Forum Index -> Non Czech Languages Here
cepi_esp
PostPosted: Sun Mar 25, 2007 1:33 pm    Post subject: SXG75 "Factory Test Mode" Problem Reply with quote
hi guys, how is the way to solve this problem?
I got it after I put a theme using QPST EFS Explorer then my handy restarted...TADA Twisted Evil ...Factory Test Mode showed up Crying or Very sad
It is really different while using BitPim, I never got it Laughing
many thanks
adfree
388.38 SMM
PostPosted: Sun Mar 25, 2007 2:18 pm    Post subject: Reply with quote
IMHO EFS Explorer tells you that you have changd something and if u want RESET...
FTM is harmless. Take your beloved BitPim. Connect. Use right Mousebutton->Reboot Phone...
Or use SXG75 Controller to change FTM into Online, or ...
There are so many possibilities. Also the whole bunch of QPST Tools is able to RESET the Phone...
cepi_esp
PostPosted: Tue Mar 27, 2007 4:25 am    Post subject: Reply with quote
yep, great deal using bitpim, thank again adfree Applause
chEVOlution
Reply to topic     Forum Index -> Non Czech Languages Here All times are GMT + 1 Hour
