kubacka začátečník
Joined: 21 Jan 2005 Posts: 38 Location: d.k.-slovensko
Posted: Fri Mar 23, 2007 8:23 pm Post subject: quick office alebo quick word funguje vám? |
Ahojte. Uz viac krat somsa pokusal rozbehat quick office alebo quick word ma fone ale zatial neuspesne. Stale to hadze hlasku nedostatok pameti ram alebo series 60 vižadovano. Podarilo sa to niekomu z vas? Ak ano aku verziu ste pouzili? dik |
yaqwsx táta fóra
 Joined: 12 Dec 2005 Posts: 1027 Location: Takové městečko nedaleko Kroměříže
209083.66 SMM
Posted: Fri Mar 23, 2007 8:27 pm Post subject: |
Pokud ti to pise Nedostatek pameti tak potrebujes 11MB C a nebo to rozbal v unmakesis a nakopiruj na kartu _________________ Děda vševěda, bůh(neplést s Bůh) == Google......
JFGI - Just Fuckin' Google It
kubacka začátečník
Posted: Fri Mar 23, 2007 8:46 pm Post subject: quick office |
yaqwsx wrote: | Pokud ti to pise Nedostatek pameti tak potrebujes 11MB C a nebo to rozbal v unmakesis a nakopiruj na kartu | Stacil by mi aj quick word len na citanie doc file. Podarilo sa ti ho rozbehat aj bez 11 mb c? |
yaqwsx táta fóra
209083.66 SMM
Posted: Fri Mar 23, 2007 8:50 pm Post subject: Re: quick office |
kubacka wrote: | yaqwsx wrote: | Pokud ti to pise Nedostatek pameti tak potrebujes 11MB C a nebo to rozbal v unmakesis a nakopiruj na kartu | Stacil by mi aj quick word len na citanie doc file. Podarilo sa ti ho rozbehat aj bez 11 mb c? |
Jo pres unmakesis _________________ Děda vševěda, bůh(neplést s Bůh) == Google......
kubacka začátečník
Posted: Fri Mar 23, 2007 9:05 pm Post subject: Re: quick office |
yaqwsx wrote: | kubacka wrote: | yaqwsx wrote: | Pokud ti to pise Nedostatek pameti tak potrebujes 11MB C a nebo to rozbal v unmakesis a nakopiruj na kartu | Stacil by mi aj quick word len na citanie doc file. Podarilo sa ti ho rozbehat aj bez 11 mb c? |
Jo pres unmakesis | Jasne dik. Mam softik pre pc, ktory mi rozbaly hociaku ap do zadaneho adresara a potom to supnem do fonu a malo by to fachat. A adobereader ti ide? Myslim ci ho symbian 6.1 podporuje. 11 mb c si nemozem hodit, lebo mam iba 24 mb flash. Proste starsia seria sxcka. |
Gwin čestný člen
0.84 SMM
Posted: Sat Mar 24, 2007 7:26 pm Post subject: |
Adobe reader nerozjedeš, používej Pdf+ od mBrain Software. _________________ Alcatel 301 => Alcatel 301 => Nokia 3210 => Nokia 3310 => Nokia 3410 => Siemens SX1 => Nokia E51-1 => HTC TyTN II => Samsung GT-I8190
kubacka začátečník
Posted: Sat Mar 24, 2007 11:09 pm Post subject: quick office |
Gwin wrote: | Adobe reader nerozjedeš, používej Pdf+ od mBrain Software. | Dik skusim.
a unmakesis je daky soft pre comp na rozbalovanie sis file? mam daky iny ale nezabral hodil eror. myslim ohladom toho quick office |
Gwin čestný člen
0.84 SMM
Posted: Sun Mar 25, 2007 12:11 am Post subject: |
jj, unamkesis je pro pc _________________ Alcatel 301 => Alcatel 301 => Nokia 3210 => Nokia 3310 => Nokia 3410 => Siemens SX1 => Nokia E51-1 => HTC TyTN II => Samsung GT-I8190
kubacka začátečník
Posted: Sun Mar 25, 2007 11:03 am Post subject: unmakesis |
Gwin wrote: | jj, unamkesis je pro pc | Ok. zozeniem odskusam. dik |
Juraba kolemjdoucí
Posted: Fri Mar 30, 2007 2:01 pm Post subject: Re: unmakesis |
kubacka wrote: | Gwin wrote: | jj, unamkesis je pro pc | Ok. zozeniem odskusam. dik |
mel jsem ten samy problem. Pomohlo naformatovat C a potom provest instalaci QO hned jako 1. aplikaci a to samozrejme na MMc. Ostatni aplikace jsem nahraval po Qo a proslo to... |
