:: View topic - A75 nenabehne
A75 nenabehne
This topic is locked: you cannot edit posts or make replies.     Forum Index -> Firmware
chude
0.00 SMM
PostPosted: Fri Oct 26, 2007 4:28 pm    Post subject: A75 nenabehne Reply with quote
prosim o radu. A75 nenabehne,jen se rozsviti modre display na 2 sec. Skousel jsem prehrat firmware, ale to jde jen s WinSwup bez Pre-Check.
Je tento [Old] telefon totalne v pr.... ? ,nebo jde jeste zachranit ?
predem dik za odpoved-i.
plesi.
PostPosted: Fri Oct 26, 2007 4:41 pm    Post subject: Reply with quote
Zkus ho odblokovat přes JOKERa.
chude
0.00 SMM
PostPosted: Fri Oct 26, 2007 4:58 pm    Post subject: re: Reply with quote
pise mi to:
Start...
Loading BootsModel(A75)...
StartBoot does not answer!
vubec nenabootuje -nekomunikuje .No Ping Mobile!
kozino
2156.42 SMM
PostPosted: Fri Oct 26, 2007 5:14 pm    Post subject: Reply with quote
A nastavil si dobre boot type ?
chude
0.00 SMM
PostPosted: Fri Oct 26, 2007 5:17 pm    Post subject: re: Reply with quote
Error: StartBoot answer code 0x00!
kozino
2156.42 SMM
PostPosted: Fri Oct 26, 2007 5:21 pm    Post subject: Reply with quote
som myslel či nastavil BootCoreBug - je to hneď pod nastavením rýchlosti
chude
0.00 SMM
PostPosted: Fri Oct 26, 2007 5:23 pm    Post subject: Reply with quote
skousel sem snad vse
kozino
2156.42 SMM
PostPosted: Fri Oct 26, 2007 5:24 pm    Post subject: Reply with quote
Možno blbá otázka, ale mal si telefón vypnutý a stlačil si správne červené tlačítko ?
chude
0.00 SMM
PostPosted: Fri Oct 26, 2007 5:27 pm    Post subject: Re: Reply with quote
presne ,nejakou tu skusenost uz mam jinak bz s tebou Jokr ani nekomunikoval
kozino
2156.42 SMM
PostPosted: Fri Oct 26, 2007 5:30 pm    Post subject: Reply with quote
Modrý display by sa mal dať odstrániť správnym nastavením kontrastu... ale neviem prečo ho ten Joker nebere... Ja som mal zas opačný problém s A52 - Joker v pohode komunikoval, ale WinSwup vôbec... nakoniec sa to na x-tý krát podarilo.
chude
0.00 SMM
PostPosted: Fri Oct 26, 2007 5:36 pm    Post subject: Reply with quote
ok. jdu ho jeste jednou flashnout ,ale tusim ze zbytecne.
chude
0.00 SMM
PostPosted: Fri Oct 26, 2007 5:59 pm    Post subject: Reply with quote
tak jsem ho flashnul ,ale jak jsem tusil problem nevyresen .
V servisnim modu pise:
Start...
Loading ServiceBoot...
Sending ServiceBoot Ok.
No Ping Mobile!
Start...
HWID: 237 (A75)
A75 lg98 Sw20 19.05.05 14:07:25
IMEI: 356475000038657
DisplayID: 37, Philips Epson S1D15G14
Code(05): OTP closed
Code(08): BootKEY is unknown
Code(0D): Keys are registered in BCORE
Code(10): Minimal access to BFB
Code(15): Complete condition
Code(19): Monitoring is switched on
Code(1D): Blocks 5121,5122,5123 are present
Battery Voltage 3850 mV.
SecurityMode: Customer
PostPosted: Fri Oct 26, 2007 6:07 pm    Post subject: Reply with quote
Ak ho dokazes spojit s Jokerom, tak daj sformatovat iba File System. Malo by ti to pomoct. Ak pohladas urcite je to niekde tu aj vo fore.
Edit: http://www.siemensmania.cz/content.php?id=743&p=4 . Bod 13
chude
0.00 SMM
PostPosted: Fri Oct 26, 2007 6:23 pm    Post subject: Re:mario_liptov Reply with quote
Problem vyresen ! diky mario .
//mario_liptov: LOCK
Akurat teraz tam nebudes mat obsah pamati tak si nahraj novy flex.
This topic is locked: you cannot edit posts or make replies.     Forum Index -> Firmware All times are GMT + 1 Hour
