:: View topic - S65 ELF + Masterpatch
Reply to topic     Forum Index -> Non Czech Languages Here
gruen2
PostPosted: Sat Feb 09, 2008 4:22 pm    Post subject: S65 ELF + Masterpatch Reply with quote
Can anyone make me a Patchbundle which include all Patches for Masterpatch and Elfloader for s65fw58 and which works in combination. Because the bundles I made crashed when I start the phone
And then I have a Problem with the mp3-player from dobby, there i can't use skins, so the text overwrite each other. the other problem is, that the player don't save settings.
Sorry for my englisch! Embarassed
D4X
(o(^^)o)
Phone: HTC Diamond
382387.67 SMM
PostPosted: Sat Feb 09, 2008 4:56 pm    Post subject: Reply with quote
Hi there, try FW from this article: http://www.siemensmania.cz/content.php?id=893 . Then unlock (as when you apply not your FF), delete images from Zbin/img, you can delete elfs too, if you don't want them... but be careful - it's whole FF in WS not only FW, so you need your files (images, data, phone numbers etc.)...
-> Nokia Lumia 800
gruen2
PostPosted: Sun Feb 10, 2008 6:20 pm    Post subject: Reply with quote
Is that the only chance, because my Datacable supports only Patching, Flash. But no Firmwareupdates.
D4X
(o(^^)o)
Phone: HTC Diamond
382387.67 SMM
PostPosted: Sun Feb 10, 2008 6:56 pm    Post subject: Reply with quote
wtf? what cable do you have?
-> Nokia Lumia 800
gruen2
PostPosted: Sun Feb 10, 2008 7:56 pm    Post subject: Reply with quote
It's a Datacable from Hama. The Mobile says that there is an DCA-510 plugged in, but with Winswup there comes Error-Messages. But with V_klay and x65flasher it works succesfully.
delpierwin
519.20 SMM
PostPosted: Mon Feb 11, 2008 4:06 am    Post subject: Reply with quote
If you're updating using Winswup, try to change it to factory mode first, then continue update.
SiemensXP | My Blog
BenQ Siemens EL71 v45 Diamond Style
Siemens ME45 Standard
Siemens A70 Almost die -- dying
Siemens S57 v17 Standard
Siemens SX1 v15 Cristal 2+
Siemens M65 Windows 7 v1.1
Siemens S75 v47 Katie Meula Case
HTC Touch Pro - Timolol's WM6.5 Stock Like ROM
gruen2
PostPosted: Mon Feb 11, 2008 1:36 pm    Post subject: Reply with quote
I have worked with Winswup, but that was with the cable from a friend. So know about I factory and normal mode. And I can tell you that it doesn't work with all settings in winswup. So please can anyone give a Pack an Elf and Masterpatch which work together?
gruen2
PostPosted: Mon Feb 11, 2008 6:58 pm    Post subject: Reply with quote
Maby is this avaible for S65fw58: http://www.siemensmania.cz/content.php?id=943 and is there an englisch faq? Because Google can't Translate CZ.
gruen2
PostPosted: Sun Feb 17, 2008 6:22 pm    Post subject: Reply with quote
i don't know why, but now it works with the elfpack 2.3 and a clean fubu.
delpierwin
519.20 SMM
PostPosted: Mon Feb 18, 2008 4:22 am    Post subject: Reply with quote
Congratulations then Applause
SiemensXP | My Blog
Reply to topic     Forum Index -> Non Czech Languages Here All times are GMT + 1 Hour
